(man/dude)
Jonny042's Avatar
Wrench sizes and allen keys
Hello all,
I've read through a number of threads about assembling a tool kit. I am planning a 3,100 mile trip driving my new (to me) G50 Coupe home from San Fran.
I have a pretty good idea from the other threads of what I may need (VISA card seems to be #1), but I was wondering about wrench sizes.
I was planning a 6/7 double ended wrench, and combination wrenches in 8,10,13,15, and 17 and a good quality adjustable 6".
Would I need the missing 11,12,14,16?
Also I was planning to bring a fold-out allen key set up to 8mm. Would this suffice?
I'll bulk all this up with a dvm, some pliers/cutters, a few other bits, and a spare fan belt and DME relay.
Quite frankly I am not too sure how useful any of this might be. My experience is it doesn't matter how many tools you have - it's actually hard to fix anything on a car, it's usually a matter of bolting on a new part. So I'm sure while I'm waiting in butt-f-nowhere for a new alternator I can buy or borrow whatever tools I might need or find a place to do the work.
Old 09-01-2010, 11:19 AM
peppy's Avatar
Cell phone is # 1, Visa is # 2.
Factory tool kit with a few fuses and relays, a fan belt and DME are about all I would do on the side of the road.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-01-2010, 11:24 AM
AutoBahned
RWebb's Avatar
I don't recall needing 11,12,14,16 on my early 911 or my '75 either.
You need larger Allens in various places - can use snap on type ones on a ratchet handle, T-bar, etc.
tools you carry depend on where you can work (roadside?) and what parts you carry or can get.
I once changed a BMW head gasket by the side of a backcountry Orygun road... but had to hitchhike to buy the part.
Old 09-01-2010, 12:01 PM
Home of the Whopper
The clutch cable on early cars is 11mm, not sure about the G50s.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-01-2010, 12:13 PM
Poor-sche Lover's Avatar
An 11mm is a good idea. I seem to remember a lot of adjustment cables using 11mm nuts.
Also, in my two long distances trips to get cars, I have yet to use any of the tools that I've brought along. That being said, I'll still bring a set on my next trip.
Depending on the car you are buying, you may want to bring some oil with you. Good luck on the trip!
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Hi
Targa Me's Avatar
AAA offers a tow package, it's something like $80 a year and they'll tow you up to 100 miles. Call 'em up, its instant acceptance.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-01-2010, 12:21 PM
Make Bruins Great Again
Por_sha911's Avatar
+1 on AAA but what do you do when you are in a place with no cell coverage? Bring fuses and a red relay (will replace black as well). Make sure you have an inflater for the collapsible spare. If the alternator light comes on, pull over immediately. It could be a broken belt (which will overheat the engine very quickly). Keep a close eye on the temp and oil pressure as well.
Joe
Old 09-01-2010, 04:17 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Arrow That should do it...
CAA Premium; 1- 200 Miles tow + 4-120 Miles tow/per year (AAA should have the same plan), and with this tool kit you cover everything.
Made by Crescent (SAE/Metric) on sale for about $90 US.
Who Will Live... Will See
Old 09-01-2010, 06:03 PM
speedy's Avatar
plastic zap straps and a roll of duck tape are always good for something?
81 SC coupe
Old 02-12-2011, 04:31 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
# 3 is a really good flashlight. #4 is a roll of plastic you can spread on the ground.
G-50 clutch is hydraulic.
Hopefully you won't have to split the cases or set pinion depth by the side of the road, so the factory tool kit plus good combination screwdriver (hex bits) adjustable wrench, maybe some allen keys and some other stuff will be sufficient. Vise grips, duct tape, maybe a magnetic retreiver. If it were me I'd take an LED headlamp in addition to the flashlight. Spare belt, fuses, DME relay, all are good if you can get them on the outbound flight.
Of course, if you're well prepared, the Porsche gods will smile on you and your car will run like a jet for the trip home.
Good luck.
Mark Petry
Bainbridge Island, WA
81 SC
Old 02-12-2011, 04:50 PM
Recreational User
porschenut's Avatar
Fan belt for sure, but in order to change it you'll need the special spanner, so make sure you have one of those. DME relay also, and a 10mm wrench to loosen the mounting nut. And fuses of all amperages and a red round relay.
And duct tape, electrical tape, and a breaker bar with a 19mm socket for removing a wheel.
Did you get a PPI? If so, ask the shop who inspected it if they recommend any maintenance items before taking it on a cross-country jaunt. Make sure the plugs, filters and other basic maintenance items are in good shape.
Old 02-12-2011, 05:07 PM
80-911SC's Avatar
maybe a dumb question but the red relay and the black relay .... what is the difference in them ....I ask because I have seen the same before that the red can replace the black but is it the other way around or ?????
Old 02-12-2011, 05:24 PM
arbita1's Avatar
Here's what I put together.
Factory Tools
The red one has a diode in it so the current only goes in one direction. It's only used on the fuel pump (on the SC). You could temporarily replace it with a black one.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-12-2011, 05:43 PM
Northern Motorhead
wildcat077's Avatar
You might also want to include a "Slime" brand tire repair kit,which includes an air compressor and a 32 oz bottle of slime which you inject in your wheel through the tire valve ...
It will fix a flat/puncture up to 1/4 inch !
I use the stuff in my ATV's and it's saved my butt many times on the trail !
I also carry a kit in all my vehicles including the Porsche.It will get you home or at least to the nearest garage .
Spare oil of the same brand you normally use,appropriate funnel and a bottle of Maguiars quick detailer with a few microfiber cloths to clean any road grime/bird poop off
your paint ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-12-2011, 05:55 PM
