-   -   Bilstein strut play...safty issue? (http://forums.pelicanparts.com/porsche-911-technical-forum/562566-bilstein-strut-play-safty-issue.html)
mdmiller911 09-04-2010 10:21 AM
I noticed a bit of play when checking the drivers side wheel bearings but when I removed the bearings and checked out the races, they both looked good. Checking further, I grabbed the strut and the movement, from what I thought, is from the upper mount. I searched the forum and found that I probably need new bushings in the insert. So my question...
I have a DE on Wednesday and don't want to miss it. Is it safe to run with the strut like this? Keep in mind that there is only a little bit of play and no clunking sounds coming from the front end.
Thanks, Mike
Eagledriver 09-04-2010 09:03 PM
My struts have tape in them to build up the bushings and keep things straight. Seems to work fine. I'm sure your struts are safe as is.
-Andy
mdmiller911 09-05-2010 06:35 AM
Thanks Eagledriver
Any suspension experts care to chime in?
Thanks, Mike
Steve@Rennsport 09-05-2010 08:42 AM
Mike,
No safety issues here,....:)
All you'll get is variable camber with worn bushings.
Sboxin 09-05-2010 09:23 AM
Recommendation for strut bushing replacement (when you decide you need it):
Craig Garrett (G2 Performance)
5424 Greenboro Dr
Grand Rapids MI 49508
garrett@iserv.net
He charged $100 +shipping with a 2 day turn around time
And his bushings are wider than Bilstein
Take care,
Roy Turner
mdmiller911 09-05-2010 11:06 AM
Great to hear...Thanks Steve
When I'm ready, I'll give Craig a call. Thanks Roy
