new member
Bilstein strut play...safty issue?
I noticed a bit of play when checking the drivers side wheel bearings but when I removed the bearings and checked out the races, they both looked good. Checking further, I grabbed the strut and the movement, from what I thought, is from the upper mount. I searched the forum and found that I probably need new bushings in the insert. So my question...
I have a DE on Wednesday and don't want to miss it. Is it safe to run with the strut like this? Keep in mind that there is only a little bit of play and no clunking sounds coming from the front end. Thanks, Mike
77 911s 3.2 944 track beater 58 TVR Grantura MkI vintage racecar Defender 90 NAS 73 CB750 Cafe |
My struts have tape in them to build up the bushings and keep things straight. Seems to work fine. I'm sure your struts are safe as is.
-Andy
72 Carrera RS replica, Spec 911 racer |
new member
Thanks Eagledriver
Any suspension experts care to chime in? Thanks, Mike
Mike,
No safety issues here,.... ![]() All you'll get is variable camber with worn bushings.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Recommendation for strut bushing replacement (when you decide you need it):
Craig Garrett (G2 Performance) 5424 Greenboro Dr Grand Rapids MI 49508 garrett@iserv.net He charged $100 +shipping with a 2 day turn around time And his bushings are wider than Bilstein Take care, Roy Turner |
new member
Great to hear...Thanks Steve
When I'm ready, I'll give Craig a call. Thanks Roy
