Question 964 valve covers on 2.8 twin-plug??
I am building a twin-plugged 2.8L engine, and thought that instead of putting holes into my lower valve covers, I would use 964/993 covers. The bolt pattern lines up, so I am told. Does anyone know why this should not work? If not, does anyone have a good used set to sell?
TIA,
Old 01-08-2002, 07:08 PM
PRO Motorsports
Tyson Schmidt's Avatar
I've heard it works fine. One cavaet. You need the special studs with the built-in shoulder that limits the amount you compress the rubber gasket.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-08-2002, 07:47 PM
Irrationally exuberant
ChrisBennet's Avatar
Steve,
When I built my twin plug motor I had this very same thought. I've seen late 3.2L cam towers with 964 part numbers so I thought "Hey I'll get some 964 covers and plug wires and I'll be all set". I tried to find some 964 valve covers used but I couldn't so I tried 993 ones instead. I also used 993 lower plug wires. Here's what I learned:
- 993 lower valve covers have aluminum inserts with holes for 6mm studs - not the 8mm ones of older engines.
- If you drill out the holes to fit 8mm studs the valve covers seem to fit OK but the covers leaked (but not from the stud holes).
- 993 upper valve covers do not fit period.
- The 993 lower plug wires have nice thick protective sleeves over the wires. I suppose this was done to cope with the high heat in this area.
I had to get the car together for a track event so I used some aluminum ones but I'm going to try 964 valve covers again. Let me know if you learn anymore on this.
-Chris
Old 01-08-2002, 07:52 PM
