-   -   New Danske pan, do i need to grind galvanize off? (http://forums.pelicanparts.com/porsche-911-technical-forum/562923-new-danske-pan-do-i-need-grind-galvanize-off.html)
robotman 09-06-2010 04:30 PM
Got me new Danske galvanized front suspension pan in. When i start to mig this thing in do i need to grind off the galvanized coating on the new pan where i am going to plug weld? Or will it plug weld just fine thrue the coating?
burgermeister 09-06-2010 04:39 PM
You can weld trough the coating - set the torch a bit hotter with a bit more wire feed. But, it doesn't weld very well, and the fumes are very toxic.
I ended up grinding most of the zinc coating off prior to welding.
After your first few plug welds, be sure to hit the area with a hammer to see if they took or if they're 'cold' plug welds (in which case, set the welder to settings for a higher gage)
robotman 09-06-2010 04:52 PM
Ok, thanks
