robotman's Avatar
New Danske pan, do i need to grind galvanize off?
Got me new Danske galvanized front suspension pan in. When i start to mig this thing in do i need to grind off the galvanized coating on the new pan where i am going to plug weld? Or will it plug weld just fine thrue the coating?
Old 09-06-2010, 04:30 PM
burgermeister's Avatar
You can weld trough the coating - set the torch a bit hotter with a bit more wire feed. But, it doesn't weld very well, and the fumes are very toxic.
I ended up grinding most of the zinc coating off prior to welding.
After your first few plug welds, be sure to hit the area with a hammer to see if they took or if they're 'cold' plug welds (in which case, set the welder to settings for a higher gage)
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-06-2010, 04:39 PM
robotman's Avatar
Ok, thanks
Old 09-06-2010, 04:52 PM
