Question Camshaft selection for a 2.7w/ Weber carbs.
I have converted my 1973 2.4 to a 2.7 with 90mm pistons & cyls., 911s heads w/ 35mm ports and Weber 40ida3c carbs w/ 30mm venturies which I plan on opening up to 34mm. The cams I have now are 14300 & 14400 which I believe are CIS cams and not suitable for this engine. I would appreciate any input in choosing the ideal cams for this combination.
Thanks, Craig.
Old 01-27-2012, 01:53 PM
depends on your pistons. if you went with euro 2.7 pistons, then E/solex cams work great.
206 637 4071
Old 01-27-2012, 02:31 PM
Second Johns recommendation. You'll be tempted to use 911S cams. Don't do it. I've raced and street driven with Solex and "S" cams. The Solex are better in every way.
-Andy
Old 01-27-2012, 10:07 PM
911_Dude's Avatar
I have 40IDAs and Solex cams on my 2.7. Love it. Very drivable and great throttle response.
Old 01-28-2012, 06:34 AM
I used the euro pistons and Solex cams when I built my 2.7. My car pulls hard from idle to 7100 rpms.
Old 01-28-2012, 06:54 AM
al lkosmal's Avatar
One of my favorite engines was my 2.7 with Webers, 9.5:1 JE pistons, E-cams, SSI's and 2in-1out Dansk sport muffler. This combo just worked!
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-28-2012, 08:41 AM
Thanks for the input, guys. I'll be in the market for a set of these cams, possibly trading up my 911T CIS cams. I have 1 more question - will my 30mm venturies be sufficient with this set-up or will I have to go to 32 or 34?
Targaman
Old 01-29-2012, 03:26 PM
911_Dude's Avatar
The Weber guru is Paul Abbott of Performance Oriented
Hes on this forum, but I cant remember his handle.
Old 01-29-2012, 03:46 PM
al lkosmal's Avatar
As a great starting configuration, I would suggest :
34mm main vents
145 main jets
180 air
60 idle
regards,
al
When i built my 2.7, I got these sizes off of the PMO website and they worked very well.
+1 for Paul Abbott. he rebuilt a set of Webers for me.............excellent work.
RGruppe #669
Paul Abbott is ( 1Quicks ) here on Pelican.
Old 01-29-2012, 04:38 PM
