I think I have the wrong fuel tank for cis
I just removed my fuel tank that has been siting for many years. The car is a 75 and the engine is a 77 2.7 cis motor. I have included some pictures of the tank outlets. Looks like one of the fuel outlets is plugged with a 19mm plug. There is not a drain plug on the bottom of the tank ala cis tank. Can I use this tank or will I need a new/used cis tank? Thank you for any help.
Chris
Old 01-23-2011, 11:57 AM
all you need is an in and an out, so yes.
206 637 4071
Old 01-23-2011, 12:27 PM
Thank you. I guess I don't need the plastic baffles. Sweet no baffles to worry about when refinishing the tank.
Old 01-23-2011, 12:43 PM
Well.. yes and no. If you drive in a straight line, when at 1/8 tank or lower, you will do just fine (till you run out of gas ;-) ) . However , if you are in the twisties doing some spirited driving, the G forces will starve the fuel pump for gas, allowing the car to lose power, and shortening the life of the pump itself. The pump uses the fuel for cooling/ lubrication to some extent
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 01-23-2011, 01:42 PM
Band.
+1; it will "work", but under about 1/3 tank (IMO) and turn left and it'll stall from the swishing. And every time you hear that sound of the fuel pump pushing air, take 500 miles off the life if your CIS pump.
Old 01-23-2011, 02:05 PM
