chris 964's Avatar
Rear noise
I have recently noticed a thud noise from the rear NS(RHD) when going over bumps, seems to happen when its cold. Once its moving for 15-20mins the noise goes. Its an 88 Euro spec, the geo was done about 4 months ago.
Checked the ARB(sway bar) mounts, shock mounts, drop links - All OK as in tight.
Engine mounts?
Old 09-09-2010, 05:09 AM
Senior Member
Jdub's Avatar
Heat seems to be the differentiator here - do you have a loose heat exchanger or muffler mount? Have any recent encounter with a speed bump or otherwise?
'78 Targa in Minerva Blue
Old 09-09-2010, 05:49 AM
chris 964's Avatar
Agreed heat is the differentiator, I checked all the exhaust system and its good and tight.
I have noticed the NS engine mount is slightly out
Old 09-09-2010, 06:59 AM
