Dashboard Gauges ('82 930)
Hey all,
All of a sudden my pressure gauge is not working, the needle does not move at all. Then about 2 days later all the lights in my dash board go out EXCEPT the one on the far left (gas and oil). What else is weird is that the gauges do not work at all while my headlights are on and the temperature needle now points "up". It is the craziest thing!
Has anyone else experienced this? Any repair ideas?
Danke!
'82 911 SC
Guards Red
Old 09-14-2010, 08:57 PM
Senior Advisor
James Brown's Avatar
Is your car a turbo or a SC? boost gage or oil pressure gage? Pull a gage out, they just pull out with a tug and a twist, and check the gage lights. Also trace the light wires to the ground to make sure there tight. They are the brown wires. If it is the oil pressure gage, that sounds like the wire is off the sender on the rear right of the engine down by the crank pulley.
08 Cayenne Turbo
Old 09-14-2010, 09:05 PM
