-   -   When checking oil where should needle be on temperature guage? (http://forums.pelicanparts.com/porsche-911-technical-forum/564531-when-checking-oil-where-should-needle-temperature-guage.html)
galileo 09-15-2010 11:44 AM
Should it be by the red? In the middle? Just trying to get a proper read.
thanks
gtc 09-15-2010 11:54 AM
Wherever it settles during normal driving.
Wil Ferch 09-15-2010 11:55 AM
about 194 degF.... typ 8 o'clock. All gauges are a bit different. Helps if you post which model year car you have.
Tip....ALL 3 things needed for proper oil level reading.
1.) on level ground.
2.) engine running ...at temp ( 194 degF)
3.) engine running at approx idle speed.... 800 RPM +/- . Even 1100 will cause a dip ( level gauge) down into red zone.
aston@ultrasw.c 09-15-2010 11:57 AM
This will help you convert needle position into degrees C
911 Gauge module overlays
Then you can decide what temp is OK for your conditions.
Great product BTW
