Dial 911
A horse with no name's Avatar
Does your '86 Carrera have this 30mm hole??
Hi...Our '86 Carrera Cab has an open 30mm diameter hole on the right side of the inner body shell below the 'A' pillar. - Does yours?
It's located directly below where the top R/door hinge bolts onto the body... The drivers side only has the door light switch...I have checked with a friend that has a '87 Coupe, one with a '86 Targa, and neither have any holes, only the door light switches.
It appears to be an inspection hole for??? Our host does not show any 30mm plastic? rubber? body plugs, and I really don't know if it should even have one in the first place...Any info on whether your '86 happens to have this open 30mm diameter hole, or with a plug in it, would be appreciated. (1.18" diameter)
Photo added:
Thanks in advance!
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Last edited by A horse with no name; 10-04-2017 at 05:19 PM.. Reason: Photo addition...
Old 09-30-2017, 09:30 PM
proporsche's Avatar
hi ,picture of it will help
Ivan
Old 10-01-2017, 01:07 AM
Hmm , yes picture would help. I think i have the same hole as you describe. Always woundered about it as i haven't seen it on other cars. But mine is a'79 930
John
1979 930 - mahle 3.4 (7.5:1),Turbokraft longneck IC, Leask WUR w/rpm solenoid,sc cams, rarlyl8 headers, tial wg, 1 bar boost, GT35R
Old 10-01-2017, 01:31 AM
Dial 911
Sorry about not posting a photo... If your '86 Carrera does have the 30mm open hole, it is very easy to see once your right side door is wide open...Now when looking straight ahead, to the front, near the top of the rear inner fender; it's located directly below the right doors door hinge where it bolts to the body... A little further down is the location of the door switch for the interior lights.
I hope this info helps you determine if your '86 Carrera has or does not have a 30mm diameter open hole...Oops!...It could have a plastic?/rubber? plug over it ay!
*30mm is 1.18 inches
Thanks again in advance everyone for your help!
Cheers!
Leonardo Da Vinci
Old 10-01-2017, 06:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Horse w/no Name, Make the effort, take a picture! Edit it with Paint or something to add a little arrow. If you are asking people to do something for you, making an effort shows that you care about the answer.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-01-2017, 06:57 PM
Dial 911
I'm sorry that you feel so strongly about having no photo...Please though, keep in mind that what I have stated is very clear.. A picture is really not required in this case as either there is a 30mm hole there or there isn't; it's not in a hidden spot.
If the right door is fully opened, and one looks right below where the top door hinge bolts on to the body, one will either clearly see a 30mm hole or no hole...Other than that, there is only the door light switch on that part of the inner body shell, which is located futher down before the second door hinge position.
Thanks for your concern!
PS - It also may already have a plug in it - Our's doesn't.
Cheers!
Leonardo Da Vinci
Old 10-01-2017, 07:59 PM
Pretty sure the hole you are referring to is for the Euro fender blinker light harness. The harness connects from the fender / wheel well, through the bulkhead with one grommet, then through the hole you see into the frunk where there is a connector for the harness. On non-Euro cars that hole is left open because it is a sealed environment. The other hole (through the bulkhead) to the wheel well in plugged. Euro cars have grommets for both holes with the harness.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 10-01-2017, 08:16 PM
Dial 911
Hi Lyle..It's nice to hear from you... How's that wound up 3.2 come 3.4 of your's going?..'Fast' no doubt!
Re the '30m hole': Yes, it is dry/sealed on the other side of it...I know of the Euro front side fender lights that you are referring to.
Canadian 3.2 cars came with the rear Euro amber signal lights, H4 headlights but not the amber lights on the side of the front fenders...I wonder why there isn't the same hole on the drivers side?..There's only the interior light switch on that side...Maybe the wiring loom for the left side entered from somewhere else.
It appears that I should not be worrying about it missing a plug... As I recall, it's always been that way but I've never paid any attention to it until I was detailing the area a few days ago.
The other Pelican from Norway also stated that his '79 930 was also missing a plug but I believe that his car was before they started to mount the extra amber signal light on the side of the front fenders.
Like 'who really knows why' Porsche did 'a lot of' different things ay.
Thanks for your input Lyle...Much appreciated!
Cheers!
Leonardo Da Vinci
Old 10-01-2017, 09:03 PM
proporsche's Avatar
Hi Horse ...basically if you like some help for most of the time picture will help to identify the problem.In your case too...but the hole you have is someone has drilled it ,no factory 911 has this hole when it left the production the line.
Also it has nothing to do whatsoever with fender blikers-turn signal lights...
Anything else is a speculation..
I hope this helps?
Ivan
on another note the hole is on front or on the side of the frame??If it is on the side ,the hole is for electrical wires from the door to the front el.harness.
If not on side then it is made by somebody at his garage.
Old 10-02-2017, 01:10 AM
Dial 911
Thanks, but I have owned three 911's over many decades now, and this is definitely a factory 'punched' very neat hole in the body at the location that I have stated...Even the inside edge of this hole is painted.
The car is an original, stock, low mileage car that was purchased new locally... As you may have read, there is a Pelican from Norway that also happens to have the same sized hole, and it is in the same location on his '79 930.
I'm now kind of satisfied, for whatever the reason that the 30mm hole is there, that it really doesn't matter to me anymore...I was just trying to find out if it was missing a body plug...Apparently it isn't...If so, I was going to try to purchase one.
Thanks again for your, and others, interest.
Cheers!
Leonardo Da Vinci
Old 10-02-2017, 02:25 AM
proporsche's Avatar
ok sounds good but out of curiosity ..take a picture for us.
I have had in my hands in my over 30 years plenty of 911`s never ever seen a hole you are talking about so make an afford and post the pic
Ivan
Old 10-02-2017, 02:49 AM
Racer
winders's Avatar
Dude, post a photo...jeez.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-02-2017, 03:24 AM
I'll get a picture from my car tonight. And you could see if they look the same.
For me, if memory serves me right, it looks more like somebody put it there than factory made.
John
Old 10-02-2017, 03:50 AM
Brew Master
cabmandone's Avatar
No hole anywhere above or below (except for light switch) the top hinge on my 1985.
Old 10-02-2017, 05:23 AM
Here is the hole on my car
John
Old 10-02-2017, 08:41 AM
Cevan's Avatar
I have an '86 coupe and mine has no such hole.
1986 Carrera coupe - black on black
1972 CB500/4
Old 10-02-2017, 09:18 AM
proporsche's Avatar
jesuss c...what a big hole if that is the same hole as in OP absolutely must have been some idiot who drilled it...
I would spray some anti rust into it and welded it back.It is structural body part..so fill it it up JAJO...
Ivan
Old 10-02-2017, 09:24 AM
Not suposed to be there!
Who ever did that, it was not a porsche engineer!
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 10-02-2017, 09:32 AM
Ivan
Jupp, it's going to disapear. The whole car is going to be taken a part in the near future for some other body repairs/restoration and a complete paint job.
John
Old 10-02-2017, 11:08 AM
proporsche's Avatar
John ..that is the way to go..good for you...same color or?
Ivan
Old 10-02-2017, 11:19 AM
