ASE Master Tech - 35 yrs
Smoking Engine - REALLY smokin'
guys - I looked at a 77 911S last week with 223K on the odometer - the engine was pouring out clouds of white smoke, but otherwise seemed to run OK - I decided to pass on the buy
- but what is the probable cause of such smoking; I'm guessing rings - can't believe the guides would be able to pass that much oil
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
there are lots of reasons / causes...........worn out, over fill of the oil, crappy re-build, bla, bla
given the year ( 77 ) probably a good call to keep going. I like the SC / 3.0 ( 70-83 ) engined cars & early 911's ( 73 and earlier ). Steve 73 911 T Coupe, Aubergine 79 3.0 Engine project |
Opps, sorry, my typo, SC 3.0's were 78-83.
loose nut behind wheel
I'd bet an overfill on oil.
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
Max Sluiter
It will probably smoke a while after the problem is fixed because oil pools in the heat exchangers and lasts there forever (figuratively).
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
This 86 Carrera (new to me) is smoking so bad I am concerned. I have the heater hose disconnected in the engine compartment and oily smoke just pours out. I know it takes some time but I am wondering if 'driving' is better than 'idling' to burn off the excess oil? This thing was leaking oil and I am sure that and my cleaning activitives are added to the mix.
Old Tee all 911s sold |
happened to me once, definitely overfill of engine oil
If it were a MM rebuild, then that explains the smoke. And, it is a very good thing to walk away from!
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
price it for a rebuild at the worst, its driveable at the best.
