loose connection id on '82 SC
I was replacing the fuel accumulator and noted some kind of disconnected electrical connection just below the fuel filter/accumulator. In the Pelican tech info center (basics part) instruction for replacing the fuel filter/accum, figure 1 shows the male connection side. Anyone know what it is?? Thanks
Old 12-22-2013, 11:06 AM
Fleabit peanut monkey
Bob Kontak's Avatar
That is the connector the O2 sensor plugs into. O2 wire will come in from the sheet metal on the left side - just look lower. Maybe a one inch hole in the sheet metal if the wire and grommet are missing
1981 911SC Targa
Old 12-22-2013, 11:16 AM
Thanks Bob -- Just wondering what it was as the SC was running just fine without it being connected.
Old 12-22-2013, 12:35 PM
Bob Kontak's Avatar
They can run ok without but while cruising your gas mileage may suffer a bit and a richer mixture can impact your cat over time.
1981 911SC Targa
Old 12-22-2013, 01:59 PM
