Ignition Coil Connections on a 78 SC Targa
I think I may have accidentally connected the (2) wires connecting to the ignition coil. Will something like this damage the CDI if the car is driven this way?
The car starts fine but doesn't idle well. The CDI Buzzes on ignition. What resistance should a good coil see between its terminals? Last edited by 78_sc_targa; 09-25-2010 at 03:39 PM.. |
Senior Advisor
Argggggg, where are you at, any pictures?, no the car won't run, yes you might have damaged it, yes it will bang you to your butt if you attempt to mess with the wires and the ign. is on, no you don't need a new one, yes I will sell you one, do tell us more about the car and yourself, sounds fascinating!
08 Cayenne Turbo |
