-   -   think i found cause of 2/3k rpm surging (http://forums.pelicanparts.com/porsche-911-technical-forum/565539-think-i-found-cause-2-3k-rpm-surging.html)
47silver 09-20-2010 07:52 PM
do you think this would cause it?
http://forums.pelicanparts.com/uploa...1285041119.jpg
James Brown 09-20-2010 07:54 PM
maybe but I doubt it :). Was this cracked all this time?
47silver 09-20-2010 08:56 PM
dont know how long it was cracked
The crack was hair line, i had the dizzy out and was checking the springs etec and when i went to put it back in I noticed a nick in the cap.
I pulled on it and it cracked in half.
I did replace the wires last year so i think it was ok then. I do not remember if i put a new cap on then or not.
i have a spare so i put it on tonight and started it,, no time to adjust the timing etc
the crack was hair line and the nick i noticed was at the rim of the cap...
i think it had to be arcing at times.
T77911S 09-21-2010 04:40 AM
surging??, definately a miss.
Joe Bob 09-21-2010 06:18 AM
The crack was ONE problem. The contacts look like a zit faced teenager working in a coal mine....
47silver 09-21-2010 06:44 AM
the cap was about a year old
what would cause the contacts to look so bad? I replaced it about a year ago..
Wil Ferch 09-21-2010 04:33 PM
Cause for cap breakage?....possibly excessive force fitting the wires onto the cap?...and not knowing it at the time it was done?
James Brown 09-21-2010 04:50 PM
Howsit feel with a new cap? The greenish color on the cap is corrosion of the brass contacts. MSD ignition? looks like strong CDI ignition burning (normal wear).
john walker's workshop 09-21-2010 05:16 PM
i get them cracked right out of the box. always do an easy pull apart to check before using.
stlrj 09-22-2010 12:21 AM
JB Weld and it's as good as new!
47silver 09-22-2010 11:56 AM
runs great
put the spare cap, adjusted timing to 5 btdc with vacuum and the car runs great.
I am amazed that it ran at all with this cap.
I do have an msd ignition with a pertronix ignitor.
Had a bad msd in the summer.
James Brown 09-22-2010 01:39 PM
Yeah they are powerfull, just change out the cap often, there cheap.
kwikt 911 09-22-2010 03:37 PM
Looks like the contacts just need a little cleaning;)
cudabnu 09-22-2010 03:42 PM
Easier to clean, you can do 3 contacts at a time!
47silver 09-22-2010 05:14 PM
good for a twin plug 3 cylinder.
I timed the engine to 5 atdc but did not try it at 6000 rpm for 35 atdc. For some reason that scares the heck out of me to run it to that without a load.
Is the 5 ATDC ok or should i time it at 6000
prebordao 09-23-2010 01:11 AM
You should do it at 6000 and don't be scared, that's really the way to do it.
Superman 09-23-2010 07:17 AM
JB Weld
kwikt 911 09-23-2010 02:10 PM
Agree. It truly is the correct way.
47silver 09-23-2010 08:44 PM
advance was 35 at around 3700
went to set timing at 6k,, did not get to 6k beforefull advance. I had 35 at aroun 3700
i am missing a distributor spring,, i think that may let the advance kick in at that rpm.
Is one spring something that was done intentionally? Will full advance at 3700 hurt the engine?
kwikt 911 09-24-2010 04:58 AM
It may start pinging.
