47silver's Avatar
think i found cause of 2/3k rpm surging
do you think this would cause it?
1975 911S Targa
Silver Anniversary Edition
Old 09-20-2010, 07:52 PM
Senior Advisor
James Brown's Avatar
maybe but I doubt it . Was this cracked all this time?
08 Cayenne Turbo
Old 09-20-2010, 07:54 PM
47silver's Avatar
dont know how long it was cracked
The crack was hair line, i had the dizzy out and was checking the springs etec and when i went to put it back in I noticed a nick in the cap.
I pulled on it and it cracked in half.
I did replace the wires last year so i think it was ok then. I do not remember if i put a new cap on then or not.
i have a spare so i put it on tonight and started it,, no time to adjust the timing etc
the crack was hair line and the nick i noticed was at the rim of the cap...
i think it had to be arcing at times.
1975 911S Targa
Old 09-20-2010, 08:56 PM
T77911S's Avatar
surging??, definately a miss.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-21-2010, 04:40 AM
RETIRED
Joe Bob's Avatar
The crack was ONE problem. The contacts look like a zit faced teenager working in a coal mine....
2012 ML350 3.0 Turbo Diesel
Old 09-21-2010, 06:18 AM
47silver's Avatar
the cap was about a year old
what would cause the contacts to look so bad? I replaced it about a year ago..
1975 911S Targa
Old 09-21-2010, 06:44 AM
Cause for cap breakage?....possibly excessive force fitting the wires onto the cap?...and not knowing it at the time it was done?
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-21-2010, 04:33 PM
Senior Advisor
Howsit feel with a new cap? The greenish color on the cap is corrosion of the brass contacts. MSD ignition? looks like strong CDI ignition burning (normal wear).
08 Cayenne Turbo
Old 09-21-2010, 04:50 PM
i get them cracked right out of the box. always do an easy pull apart to check before using.
206 637 4071
Old 09-21-2010, 05:16 PM
JB Weld and it's as good as new!
Old 09-22-2010, 12:21 AM
47silver's Avatar
runs great
put the spare cap, adjusted timing to 5 btdc with vacuum and the car runs great.
I am amazed that it ran at all with this cap.
I do have an msd ignition with a pertronix ignitor.
Had a bad msd in the summer.
1975 911S Targa
Old 09-22-2010, 11:56 AM
Senior Advisor
Yeah they are powerfull, just change out the cap often, there cheap.
08 Cayenne Turbo
Old 09-22-2010, 01:39 PM
kwikt 911's Avatar
Looks like the contacts just need a little cleaning
Old 09-22-2010, 03:37 PM
loose nut behind wheel
cudabnu's Avatar
Easier to clean, you can do 3 contacts at a time!
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 09-22-2010, 03:42 PM
47silver's Avatar
good for a twin plug 3 cylinder.
I timed the engine to 5 atdc but did not try it at 6000 rpm for 35 atdc. For some reason that scares the heck out of me to run it to that without a load.
Is the 5 ATDC ok or should i time it at 6000
1975 911S Targa
Old 09-22-2010, 05:14 PM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
You should do it at 6000 and don't be scared, that's really the way to do it.
Old 09-23-2010, 01:11 AM
Senior Member
Superman's Avatar
JB Weld
Mocha 1978 911SC. "Coco"
Old 09-23-2010, 07:17 AM
kwikt 911's Avatar
Agree. It truly is the correct way.
Old 09-23-2010, 02:10 PM
47silver's Avatar
advance was 35 at around 3700
went to set timing at 6k,, did not get to 6k beforefull advance. I had 35 at aroun 3700
i am missing a distributor spring,, i think that may let the advance kick in at that rpm.
Is one spring something that was done intentionally? Will full advance at 3700 hurt the engine?
1975 911S Targa
Old 09-23-2010, 08:44 PM
kwikt 911's Avatar
It may start pinging.
Old 09-24-2010, 04:58 AM
