-   -   Pedal Cluster disassembly (http://forums.pelicanparts.com/porsche-911-technical-forum/565565-pedal-cluster-disassembly.html)
cabriobrad 09-21-2010 05:43 AM
I am trying to redo the bushing and such on the pedal cluster, but before I start whacking at the wrong thing, can anyone offer a suggestion as to how to get the set screw/screw/roll pin/ or whatever it is from the clutch pedal?
Pictures attached
1968 911L
http://forums.pelicanparts.com/uploa...1285072977.jpg
http://forums.pelicanparts.com/uploa...1285072987.jpg
cabriobrad 09-21-2010 05:54 AM
sorry...found it...I always forget to search the tech articles.
zippy_gg 09-21-2010 08:06 AM
Well, now you need to share! :D
cabriobrad 09-21-2010 10:32 AM
Pelican Technical Article: Pedal Cluster Rebuild
it's a roll pin...came out easy as pie on mine.
RSTarga 09-21-2010 02:52 PM
I drilled mine out. Getting the new one in was a chore I used a bolt to keep it aligned as I hammered it in. It might be easier to take it to a shop and have them press it out.
cabriobrad 09-21-2010 04:39 PM
I just used a smaller diameter than the hole bolt, and a few whacks and it was out...getting the other one in was a chore until I put it in the vise just the right way, and a few twists later...done.
