cabriobrad's Avatar
Pedal Cluster disassembly
I am trying to redo the bushing and such on the pedal cluster, but before I start whacking at the wrong thing, can anyone offer a suggestion as to how to get the set screw/screw/roll pin/ or whatever it is from the clutch pedal?
Pictures attached
1968 911L
Old 09-21-2010, 04:43 AM
cabriobrad's Avatar
sorry...found it...I always forget to search the tech articles.
Old 09-21-2010, 04:54 AM
French Import
zippy_gg's Avatar
Well, now you need to share!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-21-2010, 07:06 AM
cabriobrad's Avatar
Pelican Technical Article: Pedal Cluster Rebuild
it's a roll pin...came out easy as pie on mine.
Old 09-21-2010, 09:32 AM
I drilled mine out. Getting the new one in was a chore I used a bolt to keep it aligned as I hammered it in. It might be easier to take it to a shop and have them press it out.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-21-2010, 01:52 PM
cabriobrad's Avatar
I just used a smaller diameter than the hole bolt, and a few whacks and it was out...getting the other one in was a chore until I put it in the vise just the right way, and a few twists later...done.
Old 09-21-2010, 03:39 PM
