sure the noise is not spark knock?? what octane gas do you use? how about ignition timing?
It could be broken spring. I am taking down the engine next week, My timing is just not right i cant find any bits of metal in the oil and oil pressure is running good at all time so a conrod bearing is highly unlikely, valve springs why not? I might do a top overhaul at the same time.
1983 911 SC |
Under the radar
OK, has anyone tried to advance one cam and retard the other to try to broaden the torque curve? Maybe someone has done this and can post dino numbers.
what, so one side of the engine has power at low rpm and the other side at higher rpm? pure genius!
JW, What were your customers sc l/r timing i got a bad one 0.85 and 1.12. Both out of specs.
1983 911 SC |
my cams were advanced a lot (15degrees) by the PO. the car was almost undrivable. i could not floor it, nor run it past around 3500 rpm without spark knock. retarding the ignition timing, a lot (thats what led me to check the cams), did help and gave me maybe another 1000 rpms. but, i did have other problems. mainly one injector was only putting out half the volume of fuel the others were due to a bad injector line. my point, spark knock if not a broken spring or maybe a tensionor or even cam timing?? maybe the guy that did my cams did yours ![]() i would try to find the problem brfore you tear it down, or at least eleminate some things. how is the ignition timing? advance working as it should? fuel pressures right, fuel mixture right?
As I said in post number 3, the cams can be timed exactly to each other and smack on the Porsche specification.
You can adjust a cam as little as 1/10th of 1 degree. This compares to the pin and sprocket holes of 1.4 degees. Our friends at Porsche knew what they were doing. Mike at MBE Engineering knows all about it.
Doug Was 2.7racer. '76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car. '85 3.2 stock, Orient red, comfy street car. |
dont try to put the pin in a hole next to the one it came out of. that is a bigger difference in degrees, try one opposite of the one it came out of.
Does anyone here have a left and right reading?
1983 911 SC |
depends on engine type number. 930/10 is 0.9 to 1.0.
930/16 and 930/17 is 1.4 to 1.7. engine type number is forward of the oil temperature sensor and to the left of the oil pressure sender, on the flat area.
that was tongue in cheek, by the way.
T77911S,
Quote "dont try to put the pin in a hole next to the one it came out of. that is a bigger difference in degrees, try one opposite of the one it came out of." I'll file your post #28 along with John Walkers post #24. .
