Registered Abuser
Pegged Oil Pressure Reading?
I fire the car up the last day of the month, to keep things lubed during the November to April storage period here in the frozen north. The car fires on the first turn no smoke at all. The oil pressure needle peg's the the 5 line and stays there at 900 RPM I am a little concerned no normal fluctuations at idle it should be at line 3
but I think at least it's not low oil pressure no oil light or rapid temp gain. I drive the 1/4 mile in the neighborhood then put it back in the garage needle never moves off the 5 line on the gage. It's 38F out side the garage is heated to 50 F. Could very cold oil cause this? 20W 50W Dino oil car ran great just like I had driven it for the last week. Never seen this before, Whats going on ?
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Max Sluiter
It is probably a bad connection to the oil pressure sender. Check for cracked insulation, loose wires, as well as corrosion on fuses in the front fuse block. Beyond that, a bad ground wire or a failed pressure sending unit are possible.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Wer bremst verliert
Let it warm up a bit longer and see if it comes down.
If it doesnt, Flieger is likely right.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
+1. wires are located in right rear wheel well. That wire gets pelted by sand and road dirt and the insulation will sometimes get stripped exposing the wire to possible grounding.
Tony G 2000 Boxster S |
Short in ground or wire to the pressure sensor at the rear of the engine, or the wire has come off. I think I remember that these circuits are wired so the gauge pins if the wire is disconnected. Someone else will correct me if I'm wrong. (This sensor is not in the wheel well unless I'm reading this wrong. That's the oil level sensor on the oil tank, at least on my car.)
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Ya, roger that. I was thinking level sensor as I had that problem last fall and just read the original post incorrectly.
I had similar symptoms - the solution ended up to remove the connector that goes to the oil pressure sender (on the valve cover, I believe?) and clean the contact with a wire brush. When re-attaching I flipped it upside down so it would hold better. The "teeth" of the clip had worn away a matching pattern in the "tongue," so flipping made a more secure contact.
Babak |
Registered Abuser
Cleaned the contacts on the sender and the female wire contact. reconnected
No change What's my next step on tracking this down ?
Wer bremst verliert
Didja let it fully warm up? My 71 does the same thing but al is OK once warmed up.
Registered Abuser
First good day to get the car out of the garage. I never figured it out in November.
any more Ideas? same problem Druck Pressure pegged at 5 Bars I did clean the connector no change.
I believe I had the same exact problem a few months ago. (pegged at 5-bars)
Purchased a new sendor, installed in 40 minutes, started her up, and after warm, it went to 1.5 -bars. Mike.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car |
Registered Abuser
I do not have continuity from the spade of the sender to the engine
Whats that mean ?
Sorry, can't help you on that one.
Bump
The oil pressure sender is a varible resistor activated by oil pressing into the sender. On the 3.2L the sneder is mounted to the right of the cooling fan (passenger side) down on the block just above the engine tin. It's rather large and is mounted just above the oil temp sender.
You will not get a short to ground checking it the way you did. If the connection to the sender is lost the gauge will peg at 5. Clean the contacts, make sure the wire is attached, and if that doesn't do it, check the wire with your Ohm meter between the sender and the gauge. A mouse ate mine. Took a while to find the break. Good luck. Gordon |
I had the same problem with my 911S, gauge pegged when the key was on the "on" position.
Checked all wires for shorts, no problem. Installed another gauge I had available, same situation with gauge pegging upon turning key to on position. Bit the bullet and bought a $70+ oil sending unit from our friends at Pelecan....problem solved. PS: got a used combo oil temp/pressure gauge for sale $60 + shipping. (I'd spend the money on a sending unit first!) |
I have a similar problem only my gauge stays at 3.75 bars with key on and with engine running at idle and acceleration. Checked all conn. as post suggests but no luck. Can the pressure sending you be cleaned ?
Larry 88 911 Carrera Coupe Metallic Silver |
Key on, Engine Off ( "KOEO" Key in the run position) you should have a 0 (Zero) reading. If it's at 5 with the key on but before the engine is running then it's the sender or the wiring. If this is the case you can unplug the sender to attempt to isolate the issue. That is, with the sensor unplugged (KOEO) you still read 5 it's an issue with the gauge or the harness. If the gauge reads zero after unplugging the sender, the sender is faulty. If you only read 5 Bars with the engine running (KOEO)it could still be a gauge or sending unit failure (wiring is less likely). The other possibility is a mechanical issue such as a failed bypass valve.
1989 Carrera 3.2L in 993 bodywork |
Bump
Daytona,
You can sometimes clean the sending unit. After you take it out you will see a VERY small hole in the threaded end of the sending unit. If there was some contaminate in you oil, it could work its way into the sender and block it. Carb cleaner and air pressure. Just don't shoot yourself in the face with the carb cleaner. It's going to spray back at you since there is no exit hole in the sender. Not likely this will work, but it's cheaper than a new unit and it only takes a few minutes to pull the sender out and put it back. G |
Gamatt,
How do you remove the sender, it feels as if a nut is on the bottom of the unit ,but how do you get a wrench on very limited space.
Paper Member
Mine did this once. I forgot to put the cap on after checking the oil. I was driving and it suddenly pegged so I stopped the car and looked. The cap was laying against the sender and shorting it to the engine sheetmetal.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
