-   -   I really didn't want a project this big....yet... (http://forums.pelicanparts.com/porsche-911-technical-forum/566377-i-really-didnt-want-project-big-yet.html)
DaddyGlenn 12-27-2015 07:12 PM
It is alive!!
Still much to do. But this made me :D http://forums.pelicanparts.com/support/smileys/wat3.gif:D
JeremyD 12-27-2015 07:37 PM
Woo Woo!
timgt3 12-27-2015 08:47 PM
I've been following your thread for years. Those seats are stunning. Congrats on firing her up.
DaddyGlenn 01-03-2016 04:19 PM
Thanks Tim. I wish it hadn't taken so many years. But sometimes life does get in the way.
Getting the engine running has been a huge motivator. This weekend I moved to the front of the car and got all the under fender stuff installed.
I installed the horn upgrade kit from our host. I haven't tried it yet.
http://forums.pelicanparts.com/uploa...1451865656.jpg
Ran new hoses for the windshield washer system and got the tank installed. I'll have to fabricate a new mount for the washer pump as I had to remove the old one to install the oil cooler duct. I decided to disconnect the headlight washer system, for now. I didn't work before so I won't miss it. I'll add that to the things to fiddle with after it is back on the road.
Today, I turned my attention to the front valance. And I took time to snap a few pictures for you.
This is where I started this morning...
http://forums.pelicanparts.com/uploa...1451865239.jpg
I temp mounted the valance using small c-clamps. Marked a couple spots to drill holes in the bumper for the mounts. Off with the valance, drilled the holes then added a strip of thin neoprene to serve as a buffer between the valance and bumper.
http://forums.pelicanparts.com/uploa...1451865472.jpg
Then the valance went back on using a couple M6 bolts through the bumper with fender washers on the fiberglass side. While I was lying on my back trying to hold the valance and install the bolts, I realized I should have just drilled and tapped the bumper instead through bolting it. I am not 100% comfortable with spreading the force over just the two attachment points in the from (either side of the oil cooler) and where the sides connect to the fenders. So I will add additional connection points across the bumper. Drilled and tapped, of course. And after the heck of a time I had getting the valance attached, anytime it needs to come off in the future, I will remove it and the bumper as a unit. It will be much easier that way.
This bolt was a real challenge.
http://forums.pelicanparts.com/uploa...1451866179.jpg
Valence installed
http://forums.pelicanparts.com/uploa...1451866313.jpg
So with the valance on, I put the screen over the oil cooler inlet and installed the accordion rubber pieces.
Had to trim the valance on the passenger side a tad. The pelican I purchased the valance from had already done the driver's side.
http://forums.pelicanparts.com/uploa...1451866570.jpg
Had to run out to Home Depot to get some hardware to install the screen and really fiddled with that for a good bit of time. I'll grab some black model paint and hit the hardware. Not real jazzed with the silver hardware on the black screen.
Here is the end of day picture..
http://forums.pelicanparts.com/uploa...1451866587.jpg
Now I have to try to remember how the lights and turn signals go in.
GaryR 02-18-2016 05:49 PM
Way to go Glenn, almost home!!
DaddyGlenn 02-20-2016 10:33 AM
Thanks Gary!
I guess an update is in order.
I've made a bit more progress. Had a setback while installing the headlights. did something stupid and had to replace one of the lenses. That was a task I hadn't done before but a relatively easy one, once I had the part. I've got some electrical gremlins in the turn signals. I'm thinking it is a relay, but I have just added that to my list of things to troubleshoot later.
I've pretty much finished at the front of the car, minus a couple annoying details. And now I am focused on some under car items.
Today, I've connected and adjusted the clutch cable and was about to install the axle assemblies when I discovered that I hadn't purchased new bolts and washers. Which is why I am here at the computer.... to spend a little more.
I think next on the list for today will be to assemble and mount the rear bumper and perhaps the engine lid.
Here are a couple shots of where she stands now.
http://forums.pelicanparts.com/uploa...1455993073.jpg
http://forums.pelicanparts.com/uploa...1455993097.jpg
Cook&Dunning 02-20-2016 10:50 AM
Great work Glenn: I have been following this from the start. You are keeping your project moving forward way faster than I have - very impressive work. Great attention to detail; love the color, it is a great car. Congrats, it looks like maybe the finish line is not that far away.
NoMoreALFAmac 03-06-2016 11:28 AM
what an awesome job you've done .... Very inspiring!
DaddyGlenn 05-04-2016 06:24 PM
Look what just came back from Allegheny Metal Finishing....
http://forums.pelicanparts.com/uploa...1462410528.jpg
http://forums.pelicanparts.com/uploa...1462410561.jpg
Powder coated satin black. Tires get mounted on Friday.
Horrido 05-05-2016 02:46 AM
Nice work
Derek911 05-05-2016 03:10 AM
Looking at how many years this project has gone on I wondered if some of us just like working on projects? 6 years is a long time, but why do we take on these projects? I mean, it's a car, and do we get the most enjoyment out of driving it or working on it? I love driving my car, but I also love working on it. But sometimes I think we let projects take large chunks of our lives. Sometimes I have to stop and tell myself not to do it... Not just with cars, but with things around the house as well. I love projects, but the satisfaction and frustration is a love hate relationship. After all this work I really hope you get to enjoy driving it. Hopefully you won't get it so perfect that you won't want to drive it.
DaddyGlenn 09-25-2016 05:06 PM
I have been working on it. I just haven't taken the time to share any update. So this is where I am. With the completion of the carpet install today, my list of big things to do is done! http://forums.pelicanparts.com/support/smileys/wat3.gif
Now I just have a long list of little things to correct or complete. Nothing on that list is necessary for me to drive it.
It is registered. I've reactivated the insurance and all it needs now is an alignment and to pass the state inspection.
Here are a few pictures:
http://forums.pelicanparts.com/uploa...1474847874.jpg
http://forums.pelicanparts.com/uploa...1474847924.jpg
http://forums.pelicanparts.com/uploa...1474847956.jpg
http://forums.pelicanparts.com/uploa...1474847983.jpg
JeremyD 09-25-2016 05:50 PM
Love it!
Tom '74 911 09-25-2016 07:22 PM
Fantastic job Glenn. I remember when you started this thread... a few years ago now... way to stick with it! It looks really great!
Happy driving!
Tom
DaddyGlenn 09-26-2016 03:15 AM
Thank you gentlemen. I have owned the car for about 12 years and this reconstruction has taken up the last half of that time.
I have learned so much. I could not have do it without the encouragement and tutoring of those on this board. The next time I take on a build like this, it will be easier and take much less time.
CBRacerX 09-26-2016 04:38 AM
Looking great! Well done getting to the 'finish line"
gregwils 09-26-2016 05:20 AM
Hats off to you Glenn for amazing perseverance. Most projects like this get sold as a 'project'. Quite an accomplishment for a single person.
911 tweaks 09-26-2016 10:27 AM
looks greeeeat glenn...!! nice color combo & contrast...
tell us how she runs after you are on the road for a bit and get a minute...
way to see the project thru...!!! enjoy... bob
78-911SC 09-26-2016 11:01 AM
Greg is that a shot over the bow in regards to Glenn being single? Ha. Definitely more difficult with a wife or kids. Great job no matter the circumstances.
DaddyGlenn 09-26-2016 03:39 PM
Yes, I have a wife and 4 kids (now 14, 16, 17 and 20) and they each did their share of keeping me away from the project. And I had several self-inflected household projects, too. But I can be pretty tenacious.
