Flat Six
Flat Six's Avatar
New Pelican -- TIA for the advice
Been lurking for a while and appreciate all of the technical advice I've been able to gather and put to use so far. I also have seen enough 'new user' posts to know that pics are appreciated:
Bought this as a project and something to tinker with. So far I've replaced:
-- Washer Pump
-- Turn Signal Switch (have relay kit; next on the list)
-- Shifter Bushings
-- Trans Oil (and drain plug -- will create separate thread for THAT nightmare)
-- Air Filter
-- Oil & Filter
-- Cap & Rotor
-- Spark Plugs
-- Front and Rear Speakers
-- Tires (Bridgestone RE760s all around)
-- Door Moisture Seals
-- Power Seat Switches
I've also checked alignment and re-set front caster / camber / toe
Upcoming:
-- Door weatherstripping
-- Tracking down various electrical gremlins
-- Audio head unit
-- Re-skin steering wheel
Just wanted to say hello, and thanks to the Pelican community for helping me get this far (and thanks in advance for the helpful advice that I haven't yet asked for!).
Old 09-27-2010, 02:02 PM
Hi
Targa Me's Avatar
Nice looking car. Welcome
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-27-2010, 02:10 PM
wannabee wannabee
WIL84911's Avatar
Good looking car! Welcome fellow black coupe owner!
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 09-27-2010, 02:44 PM
Nice car and welcome aboard. I always liked the black and tan combination.
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 09-27-2010, 02:46 PM
winter
Winter's Avatar
Sweeeeet ride, my man. Very nice indeed. Love the black, it looks badass.
Tom
'76 Targa
Old 09-27-2010, 02:47 PM
Make Bruins Great Again
Por_sha911's Avatar
Welcome. What year is the car? If you don't have records to say when its been done I suggest you will want to:
-Inspect fuel lines. Replace the fuel filter.
-Flush the brake fluid and inspect the lines.
-Check the battery for proper charging and no corrosion.
-Make sure you have the appropriate emergency items: fuses, relays, fan belt, spare tire inflater...
Joe
Old 09-27-2010, 02:57 PM
Oh Haha's Avatar
Welcome aboard the crazy train, er, Pelican.
Classic looking 911 you have. The black/tan combo really looks nice.
Pacific Blue
Wayne
Old 09-27-2010, 05:01 PM
Flat Six
Flat Six's Avatar
Thanks for the welcome, all. For some reason my signature didn't show, but it's an 85 w/sunroof.
Joe, your list of additional items is helpful; thanks. I've inspected brake lines and flushed fluid. Battery's good (load tested okay), no corrosion; will probably replace ground cable when I pull the battery to run new headlight wiring. Have fuel filter; that'll get replaced shortly too. Also carry extra fuses, relays (inc. DME), bulbs, tire inflator, and belt. Found nearly everything I need at Pelican; shipping is sooooooo fast -- thanks Wayne and crew.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 09-28-2010, 01:44 PM
Obsessed
sobamaflyer's Avatar
that sure is a pretty little "project".
I'm sure you have found like many of us the longer you have it the more projects we seem to see that need doing. Good luck and congrats
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 09-29-2010, 10:12 AM
Welcome to the slippery slope of a 1985 Carrera. It is an addiction.
Old 09-29-2010, 02:01 PM
