911 SC Alignment specs
Hi
I need to do the alignment on my SC. The hunter machine specs, and the specs in the all data program all are different. What are the general recommended factory specs for the car front and rear. Street use only. Here is what the specs on the car read now: LF camber -.8 deg RF camber -.4 deg LF caster 6.1 deg RF caster 6.0 deg LF toe .08" toe in RF toe .07 " toe in LR camber -1.0 deg RR camber -1.1 deg LR toe .06" toe in RR toe .07" toe in The toe specs vary from 0" to .08 on the front according to Hunter program and the front camber range is -.2 deg to .2 deg the all data has a caster spec of 4.0 deg Thanks |
The specs in the all data program are factory spec.
Yeah, but it's a good question, because the specs that work best for the individual user may be different from those factory specs. For instance, what's best for a car that's used for track days? What's best for one used for touring? How does ride height influence what's best - if indeed it does?
| All times are GMT -8. The time now is 07:03 PM. |
