911 SC Alignment specs
Hi
I need to do the alignment on my SC. The hunter machine specs, and the specs in the all data program all are different. What are the general recommended factory specs for the car front and rear. Street use only. Here is what the specs on the car read now: LF camber -.8 deg RF camber -.4 deg LF caster 6.1 deg RF caster 6.0 deg LF toe .08" toe in RF toe .07 " toe in LR camber -1.0 deg RR camber -1.1 deg LR toe .06" toe in RR toe .07" toe in The toe specs vary from 0" to .08 on the front according to Hunter program and the front camber range is -.2 deg to .2 deg the all data has a caster spec of 4.0 deg Thanks
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
The specs in the all data program are factory spec.
5String
Yeah, but it's a good question, because the specs that work best for the individual user may be different from those factory specs. For instance, what's best for a car that's used for track days? What's best for one used for touring? How does ride height influence what's best - if indeed it does?
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
