I give up. My left (driver's) side electric window works fine. But the electric side mirrors - both sides - AND the right side window don't. I have checked fuses and I have even exchanged the wires on the left and right window switches and then the right side switch works the left window fine, so I am pretty certain it's not a switch problem. There has to be some connection between the mirrors and the right window I haven't figured out. Any suggestions out there?
The first thing to check is the contacts on all the switches. They will get a buildup that affects the contacts. We take the switches apart and clean the copper contacts with an alcohol dipped Q tip. If no Q tips, a pencil eraser will clean them off.
That said, we finally had to replace the switch for the driver's mirror. It's and easy swap. |
