Couple of oil leaks, need some tips please.
Hello,
Need some advise and tips on the best way to take care of these two oil leaks. The first is on the bottom flange of the oil cooler. I checked to see if the bolts were loose, but they were not. I'm assuming I need to change out the o-ring, is that correct? Can this job be done without pulling the engine? Any advise on what else to look at once I remove the oil cooler? ![]() The second one is this hose fitting. I checked this one too, and it was also tight. What do I need to replace on this one?? ![]() Thanks for your help!! |
Senior Advisor
the hose is easy, need to rebuild the rubber part of the hose. The hard part is getting it off. Once you do, a new rubber hose can be crimped on like the old one. Take it to a metric hose shop.
The oil cooler seals can be changed with the engine in the car but it's tight. Procedure in the Bentley and/or 101 things.
08 Cayenne Turbo |
