fxeditor's Avatar
Rapid Turn Signal
Hi all,
I have developed a new little issue with my '87 coupe over the last couple of days. Whenever I turn on my left turn signal it flashes very fast while the right signal flashes at its normal cadence. What's going on? I have tried doing a search but I haven't found anything on this issue.
Thanks in advance for the help,
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 03-28-2011, 11:52 AM
Michael,
In my (limited) experience, I always heard that it was the turn signal bulbs that caused this. Did you check to make sure the front and rear turn signals are actually working? I would also check parking lights, and the emergency flashers to make sure they all work. It doesn't seem like the problem is with the flasher, as it works nomrally for one side.
If these all pass, then it is beyond me...
Good luck...
Craig
77 Ice Green 911s w/3.0
Old 03-28-2011, 12:02 PM
Wash. State
nesslar's Avatar
Yep, you may have a dead bulb either front or rear on that side....
Old 03-28-2011, 12:14 PM
viscirid's Avatar
Hi Michael,
Check the ground wire on your signal light as well. Had the same thing happen to me, turned out to be a loose connection on the ground wire.
V.
88 Carrera Cab
Old 03-28-2011, 01:37 PM
fxeditor's Avatar
Great, thanks guys I'll check the bulb and the ground tonight!
-- '92 Miata
Old 03-28-2011, 02:10 PM
dshepp806's Avatar
grounds or wrong bulb selection.
Doyle'
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-30-2011, 06:57 AM
Wash. State
nesslar's Avatar
I had one light (front marker, not the blinker) that at first was "iffy", only worked when it wanted to...connections just needed cleaning.
Old 03-30-2011, 07:24 AM
Garage Queen
PorscheGAL's Avatar
Sometimes this is caused by the turn signal switch going bad. In that case you will replace the switch in the steering column.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 03-30-2011, 08:19 AM
Now accepting US $ at par
dienstuhr's Avatar
Seriously? This is a pretty common automotive issue. Fast flashing is generally caused by a burnt-out bulb in the same circuit. Check that first and you will probably have your answer.
Of course it could be mystery shorts or a bad flasher but check the simplest thing first.
Cheers
d.
1985 911 Carrera Coupe
2015 Volkswagen GTI 6-spd
some motorcycles
Old 03-30-2011, 12:45 PM
kkkarpuk's Avatar
This has happened to me when the bulbs are loose in the holders.
Old 03-30-2011, 03:51 PM
Doyle'
What he said. Since it just happened you likely have a bad bulb, but using the incorrect wattage will also cause this issue.
Old 03-30-2011, 03:53 PM
