Tired Member
I have a parts washer I got at Harbor Freight. I use a water based solvent and would like to add a heater to improve the efficiency.
If you have built a heater or purchased a heater, please share your solution. Pictures would be greatly appreciated.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Alps Adventurer
Which one? Are you talking about one of these...
![]() I have thought about a heated parts washer that uses pressure, much like a pressure washer. One where you insert the part and then close the lid of the washer. In your case, what about a heavy duty aquarium heater. You are going to need some watts though, because whatever you heat up will be lost easily. |
Tired Member
That looks like it but without the wheels.
I was thinking about adapting a hot water heater element but can't figure out the best way.
Alps Adventurer
Another possibility; one of those engine heaters that uses a magnet to hold itself to the block. Problem again is heat loss that the tank will give off. |
![]() Great idea. This is something I would like to do as well. The heater element would need to be immersed in the solvent and have a thermostat to control the temp. Len
Banned
Where does the water come from on that thing? Do you fill an area and then it recirculates.
I wouldn't put electrical any where near something like that, but what about a propane barbecue underneath. Maybe just put the parts in the dishwasher. |
Why not use an in-line car block heater?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Banned
Something like this underneath or to the side would heat that thing up pretty quick.
![]() I use these at work all the time. They heat things up. |
Tired Member
I'm thinking along the lines of a 120v water heater element like Traveller suggested. I don't need anything complicated. Just something I can plug in/turn on for short periods of time. It has to heat the solvent directly.
I've thought about a spa heater but that would involve a second pump ($$$) to circulate the solvent through the heater.
Tired Member
Any idea how fast the 300 watt unit ($15.99) would heat 30-40 gallons of solvent? Correction: 20 gallons.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec Last edited by DaddyGlenn; 03-12-2011 at 05:34 PM.. Reason: Corrected volume of solvent. |
You can spend a bundle on heating and controlling the temp...or you can get a cheap/used dishwasher. The high pressure pump is built-in; there are racks for lots of parts/bits. It has a heater built in. And, it's 120v. You can get standalone units or just enclose an under-the-counter unit with plywood. Pour in your solvent and put the drain in a 5 gallon bucket.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
30 gallons huh? you might need 4 or so. it takes about 1 - 2 hrs with 2 to heat my 5 gallon plating tank. that's with a starting temp around 50 degrees.
tharbert probably has a better idea unless space is too limited. |
I simply added a 120 volt hot water heater element (the largest I could find, which was something like 2000 watts) and the associated hot water heater thermostat. Total price of parts was something like 30 bucks. I can get my tank to 120 degrees without too much issue. Like yours, it is a generic 40 gallon Chinese unit.
Obviously, you only want to use aqueous based fluids. I'm very happy with some ZEP purple power concentrate, which one heated does an amazing job. see: Camco 2000 Watt, 120 Volt Screw-In Water Heater Element - 15120 at The Home Depot and Camco Metal and Plastic Single-Pole Thermostat with High Limit Control - 15449 at The Home Depot Add some wiring and an appropriate switch and you are done. |
Why not use an electric hot water tank? That is what they are designed for.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Tired Member
This is what I was originally thinking. Can you give me some detail on your installation? Pictures would be great, too.
SAIGON 68
the little local hot water heater that goes under the bathroom sink. home depot? 110v.
Alps Adventurer
I doubt there are much more than 5 gallons in it. |
Tired Member
Still like the idea of fabricating something from a water heater element and thermostat.
Alps Adventurer
As for using a hot water tank heater as it is, I would not be thrilled having the hot terminals so close to water, especially when using my water based degreaser which I believe is very slightly conductive. Those heaters are meant to be screwed into a hot water tank. |
