Banned
how to find vacuum leaks ?
following my stuttering woes i am now looking for vacuum leaks. what's the best way to proceed ?
19 years and 17k posts...
Spray carb cleaner around carefully and see when the idle evens out, the place where you sprayed is the location of the vacuum leak. Or, you can do what I did several years ago and replace all the vacuum hoses and clamps at the same time. I got the hoses from our host and the clamps from McMaster-Carr...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
porsher
If you have a really hard to find vac leak some shops have a smoke generator that hooks up to the air inlet. The system is pressurised just a few pounds and leaks are shown by smoke trails. In my case it assured me there were no vacuum leaks and I could eliminate that from the search.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
i use oxygen from an oxy/acteylene torch setup. just the oxygen. open the valve to a low flow and run the tip around any suspected leak areas. the idle will speed up if it's sucked in. better than spraying messy aerosols all over.
I always use carb cleaner liberally over any suspected area. You will not have a mess since it evaporates so quickly, you will never know it was there.
Besides, I don't think that oxygen tanks are very common items in most home garages. Last edited by stlrj; 10-02-2010 at 02:41 PM.. |
RETIRED
Or Quick Start/Ether...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I use Ether, but never underestimate the effectiveness of a strong flashlight, an inspection mirror, and your fingertips.
ether is EXTREMELY flammable. put tape on your eyebrows and wear a hat. shaving is optional.
shop vac
i put a tennis ball in the exhaust pipe. and connect the outlet of a shop vac to the throttle body with a fitting and clamp.
i bought a bunch of 4th of July smoke bombs. light one and put it on the intake of the vacuum, start the vac, it will suck in the smoke, pressurize the intake system, and you will see the leaks,, Be patriot and use red , white or blue smoke. Worked for me, i found out my air box was cracked at the seam.
1975 911S Targa Silver Anniversary Edition |
I have seen same results with carb cleaner as with water. Fine mist works well. May depend on the severity of the leak though.
1971 Porsche 911T Targa 1986 Porsche Carrera Targa ..one of them has got to go.. decisions, decisions |
I took the valve assembly off of an old propane torch and added 6 ft of clear plastic tubing to it with a length of old 1/8" metal brake line tubing on the other end (covered the tubing with shrink tubing to insulate it) and then just run small amounts of propane (in short bursts) and the possible leaks.
Lorne M.
83 SC |
I use an unlit propane torch to find vacuum leaks. Using a gas to find a gas leak is much more effective than using a liquid, and a lot cleaner. My experience is some engine rev up and others stall, depending on the idle mixture and engine management system.
Paul |
Using spray water will lower the revs and might make it stall. I have not tried it myself, but sounds like the safest method so far.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
a way that worked for me - use one of those auto stethoscopes - with a long piece of tubing run the end around areas that leaks may be, you will hear a whistling sound when you find the leak.
Everybody seems to recommend this carb cleaner method, but when I tried it on my SC, I couldn't really use it on the left side of the engine where the air filter inlet is, since it would get sucked in directly to the intake. How do you check the pipes on the inlet side? You really can't spray anything there and get an accurate indication.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
I use WD 40. It's propelled by propane in the spray can version, but the propane is diluted. It will still aid in starting a car if that's all you have, so be careful with any of this stuff. |
Fleabit peanut monkey
Kind of spendy though when you can get starting fluid for $3.99. Amazon.com: Specialty Kits: Home Improvement Edit - After Milt's post I read the recap of the Apollo 1 disaster. Says in there NASA had no idea how fast stuff burns in 100% O2. I am liking the replace all hoses and/or water test more and more. http://en.wikipedia.org/wiki/Apollo_1 Last edited by Bob Kontak; 10-03-2010 at 06:10 PM.. |
