SC Power Mirror Switch Wiring
I have looked at a wiring diagram for my mirror toggle switch on my 78 911SC. There are no pinout numbers on the diagram and none on the switch either. Any idea how one is supposed to figure out which wire goes to which contact pin? I was told that this switch probably had a tag on it with the wiring color codes, at one time.
Senior Member
Hello
The switch has a little decal with the color codes. Those can fall of and maybe they are lying inside the door. Maybe someone has a pic and cam post it here ? Grüsse |
