Compression Test Pressures
From time to time there are posts as to what expected compression tests pressures should be. (All the leak-down bigots can stop reading here.) For the rest of us a compression test is simple and actually measures what an engine does.
Here are the two websites that have the equations:
http://www.type2.com/library/engineg/comrat.htm
http://www.engineeringtoolbox.com/air-altitude-pressure-d_462.html
I've put together a small table with the expected pressures for different CR's and elevations. Remember too that the spread of values for a given engine is more important.
Old 09-03-2008, 11:42 AM
Free minder
Aurel's Avatar
Nice and handy, thanks !
Perfect timing, as I am going to check my compressions tonight.
I assume that external baromatric pressure should affect results as much as elevation.
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 09-03-2008, 12:40 PM
Aurel
If you want to do it that accurately you can plug in the exact pressure in the formula in the first reference. I don't think that the formula is that accurate though.
Old 09-03-2008, 01:11 PM
Platinum Member
dad911's Avatar
I believe that cam timing, overlap/duration will change the results. Also if test is done warm or cold or wet/dry (wet=oil sprayed in cylinder)
Interesting article here: http://en.wikipedia.org/wiki/Compression_ratio
I believe the race scrutineers have a device to check compression ratio, but it is done by volume.
But enuf said, I apologize for the reply because I am admittedly a Leak-Down Bigot. But I'm trying, in a group that meets once a week, and the meds help.
Old 09-03-2008, 02:46 PM
I'm an elevation bigot. Your nice chart leaves out my part of the US.
For that matter a rather large part of the western US over 4,000 ft.
However we are somewhat used to being ignored. Thank you.
If we are ignored, we don't have to deal with folks moving here and changing our way of life.
Thank you for your efforts.
We highlanders can extrapolate the necessary numbers for our part of the world.
We'll also add in the effects of "the heat of compression" to get to a more accurate number.
It's the thin dry air, we just aren't understood by lowlanders.
Doug
Was 2.7racer.
'76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car.
'85 3.2 stock, Orient red, comfy street car.
Old 09-03-2008, 05:00 PM
ASE Master Tech - 35 yrs
larrym's Avatar
interesting
- my 2.7 with 8.5 pistons and solex cams pumps 165 on 6 strokes at 2800" altitude
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-08-2010, 07:27 PM
Originally Posted by larrym View Post
interesting
Yes it is interesting, either;
a) You've broken the laws of physics (Don't forget to apply for your Nobel Prize.)
b) Your gauge reads high
c) You have a higher CR than 8.5. If your engine has carbs there could be carbon buildup in the heads. This gives a higher CR but sadly not better performance.
Old 10-09-2010, 07:44 AM
larrym's Avatar
Bruce Anderson writes in the 911 performance handbook-2 that a good 911 engine should show 130-170 psi - p.46
Wayne Dempsey's book gives a complete procedure for checking compression begining on p.14 and uses 150 psi and an example pressure
Old 10-09-2010, 04:10 PM
