Fanatical User
2.4T Compression 80 x 6 - ok?
I know compression on 2.7, 3.0, and 3.2 motors, but unclear as to what a 1973 2.4T motor should be. The one available to me reads 80 across the board before putting carbs on. Is this acceptable?
1975 Carrera, #16 - now POR-137 LIME GREEN! ![]() 1969 911 - 3.6 Varioram, 930 brakes, LSD! Yikes....SAND BEIGE! ![]() 1972 911T, Silver MFI coupe with "S" Options as from the factory! S Registry #3000, Dan's Drive #1 |
Friend of Warren
Should be closer to 120, but maybe their gauge reads different. Or it could be an engine that is shot and needs a rebuild.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Does it run?
How does it run? Has it been sitting idle for a long time? When was the last time it ran? If it runs and sounds decent, put a few miles on it and then adjust the valves. You may get a different reading. |
Fanatical User
Yes, it does run. Sat for about 5 years. Run well? That I don't know. Thoughts?
Home of the Whopper
80 is very low. My lawnmower is more than that. I would do a leakdown just to verify. If the 80 is accurate I would expect a leakdown to be over 20% and be VERY close to rebuild time.
My bet is closed throttle plates giving a low compression test.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
PRO Motorsports
Did you do the test with the throttle wide open?
With individual throttle bodies you have to have the throttle wide open to get a proper reading. And a fresh battery too.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
ASE Master Tech - 35 yrs
way too low
- culprits can be bad rings, not enuf pump strokes (6 needed ), closed throttle, weak cranking, or (unlikely) universally and equally leaking valves - a leakdown will tell a story , cold or otherwise my 2.7 8.5 CR pumps 165 with solex cams - cool block - OAT = 85 at 2800 altitude (readings 2 weeks ago) I had that engine dyno'd today - it makes 125 rear wheel HP and flat 112 torque curve from 2800 to 6500 rpm with webers and stock distributor curve
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Home of the Whopper
Larry I agree with everything you said. But more importantly, I LOVE your signature.
The older I get, the better I was. Just classic!!
Bruce Anderson writes in Performance Handbook 2 that a good 911 engine will show 130-170 psi
our guru Wayne Dempsy's book has a complete procedure outlined on page 14 and uses 150 as an example reading
