RSM-M491's Avatar
Question Dangling Wire in Dash
Need some help, went to remove my speedo so I can send it off to get repaired, and when I pulled it out I saw this wire behind the gauges hooked to nothing! Should it be hooked to something?! If anyone can tell me where this one goes I will be really impressed! 8-) I tried to follow the wire, and it seemed to go down right below the rpm gauge, but not for sure! Also, anyone have a good way to tag the wires on the speedo, so I know how to reconnect them when I get it back?! It is a lot of wires, and I do not want to screw it up! Oh, and how do I disconnect that damn shift light indicator?! ha!
Oh, the pic is taken with the speedo out, and the rpm would be to your left while sitting in the car...
Thanks!
Rod
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 10-12-2010, 04:45 PM
crustychief's Avatar
It looks like a ground wire.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-12-2010, 04:46 PM
Hodgey's Avatar
check your wires on the back of your gauge: there are two terminals that each have 3 wires on them and I seem to recall one set being a ground set of brown wires.
I just did mine not too long ago. I sent mine to North Hollywood Speedo and they were outstanding in terms of service and workmanship.
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 10-12-2010, 04:53 PM
RSM-M491's Avatar
I will check that now.......... I am planning on sending them the speedo! How did you tag your wires, so you could make sure to put them back properly, looking for a good way....
Ok, I took a look, I count 6 wires 3 pairs of 2, a large white plug, and the 3 wires going to the bulbs. Next to the white plug there is a space that has nothing attached, but not sure if something SHOULD be attached there?!
Thanks!
1989 911 Targa M491
Old 10-12-2010, 05:07 PM
aj88cab's Avatar
These photos might help. It looks like all the guage wires are grouped and come out of harnesses. The wire you asked about appears to be solo. Also I don't see an individual ground that has that type connector. So I'm thinking is goes somewhere other than the guages.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-12-2010, 05:48 PM
Weekend Mechanic
vulcan300's Avatar
The best way I can think of for marking the wire bundles is to wrap each wire or bundle of wires with a piece of tap and mark each piece with a number. then either mark the same number directly on the back of the gauge next to each connection, or put pieces of tape on the back of the gauges and mark those up if you don't want to mark up the gauges themselves.
J
86 911 Carrera Targa
Old 10-12-2010, 05:54 PM
Send a message via Yahoo to shnewberry
I have an '84 and just last night pulled the instruments out.
Assuming you can rule out the fact it is a ground from the speedo.. there is a group of brown ground wires under the dash, just to the right of the steering column (as you are facing the steering wheel). There is a welded ground spade on the steering column tub that has one of those ugly looking multi-spade connector clusters that are connected to the ground under the dash. See if it looks like there is an empty lug there.
I have wires slipping out of connectors left and right now that I am into it. Good luck.
Seth
1984 Carrera and about 150 ziplock baggies.
Old 10-13-2010, 02:30 PM
As long as you are sending them your speedometer, you can have them make a new face blocking off the shift light.
Larry
Red car w/black tires
Old 10-13-2010, 03:53 PM
RSM-M491's Avatar
I thought the shift light was on the TACH?!
1989 911 Targa M491
Old 10-13-2010, 04:26 PM
