topcarbon's Avatar
Banging in the front end
I have a 1977 911S.
Someone along its ownership put nylon bushings up front. Its not a squeak but a banging/rattling. Its not loose.
The mechanic is putting the car up on the hoist tomorrow.
What could possibly be causing the banging?
Old 10-12-2010, 05:38 PM
pete3799's Avatar
Loose strut insert?
Pete
79 911SC RoW
Old 10-12-2010, 07:11 PM
PRO Motorsports
Tyson Schmidt's Avatar
What Pete said or if the bushings were not fitted properly, they may be binding.
I've seen plastic bushings that seized up and eventually twisted the front mounts out of the front suspension pan.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-12-2010, 07:35 PM
ratpiper71T's Avatar
I second the posters above. This is much less severe than banging in the rear end.....
No help here, I know...
Old 10-12-2010, 09:30 PM
topcarbon's Avatar
Will have it checked.
I cant imagine it being a undefinable.
Old 10-13-2010, 04:19 AM
I 2nd pete3799, I had a similar problem and my front strut inserts were loose.
73 911T MFI Coupe, Aubergine
Old 10-13-2010, 06:08 AM
"farking Porsche hero"
Rich Lambert's Avatar
Check the sway bar bushings.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 10-13-2010, 05:33 PM
and make sure the sway bar mounts havnt broken loose
Old 10-13-2010, 05:57 PM
topcarbon's Avatar
Okay, this is the story.
The A-arms rusted and created a 1/10th gap with the nylon bushing. So, the shop found a nice pair at a salvage yard and put in some stock bushings.......all is tight again.
Old 10-20-2010, 05:03 PM
