Help needed : CHT calibration with Megasquirt
I've been using a Microsquirt ECU with my 3.2 Carrera engine for a while now and been very happy with it, except for the calibration needed to read the correct engine temp off the CHT, I have tried so many different calibration numbers and all failed to give me even a close temp number! .. it seems the CHT sensor is far from linear .. Can any one share his calibration numbers with me please?
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
https://forums.pelicanparts.com/porsche-911-technical-forum/1052215-verify-my-cht-sensor-test-results.htmlSee this post, it links to the datasheet from Bosch.
__________________ 1985 Carrera 3.2 |
Bosch datasheet gives following resistance values: ![]() I don't know what the Microsquirt program wants/needs (eg voltage or resistance), and you don't say. Motec has "Bosch 2.5K" as a standard type, although they do provide a voltage table for manual calibration in their datasheet: https://www.motec.com.au/filedownload.php/55001_water_temp_sensor_datasheet.pdf?docid=1326: which looks like this: ![]() The Bosch datasheet used to be here (checked; it still is): Temperature Sensor NTCÂ M12 This thread has the resistance values from the factory shop manual as well: Verify my CHT sensor test results
'77 S with '78 930 power and a few other things. |
