engine shroud
Found an old engine shroud with a bunch of other parts that came with my 73.5 CIS.
Any thoughts please if it will fit other years?
Thanks,
Rob
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 10-28-2010, 08:48 AM
Grady Clay's Avatar
That is for the CIS ’73.5 911T although it will work with MFI. With carbs, it needs the injection nozzle cutouts covered.
The hose fitting above #1 cylinder is for the fuel tank evaporative emissions system.
It will not work properly with pre-’69 as it has the provision for the coil (ignition transformer) on the fan housing. That can be modified.
All CIS fan shrouds have a lower profile to clear the air box so they don’t flow air as well as ’73 (MFI) and earlier.
They do have the larger duct and removable cover for the engine oil cooler as from ’72.
It appears to be in good, original condition.
Someone will need it.
What 'other' parts?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-28-2010, 10:05 AM
Thanks Grady.
I do plan to sell it since the one on my engine is in good condition. In the box with this shroud looks to be a fairly complete engine tin set, I will assume for a 73.5 CIS engine but might be MFI. The PO seems to have had a mixed bag of parts. I will need to compare it to the engine I have to be sure. Have an Behr oil cooler, a engine cross bar support for mounting the engine to the chassis, a coil, CIS air cleaner housing and maybe a few other odds and ends.
I also will be selling off a 72 2.4 T engine. Unfortunately it's locked up and missing it's fuel injection & muffler. Otherwise plenty left to pick from and reuse.
I'll be posting shortly with pics.
Thanks again!
Rob
Old 10-28-2010, 11:33 AM
