jamesjedi's Avatar
Cylinder Leakage Tester: Which One
Is there a big diiference between Snap-on and Longacre?
Old 10-22-2010, 06:09 PM
Mark S
I would guess just the price, a pretty simple tool. I would get the least expensive.
Old 10-22-2010, 07:21 PM
jamesjedi's Avatar
Thanks. I have always found that quality is expensive when it comes to tools, usually much more expensive. It is not always worth the price. However this is a measurement tool.
Old 10-23-2010, 06:05 AM
Mark S
Agree on tools in general but this device is one of the simplest of simple. I could fab one in a hour or two that would accomplish same with accurate results as high dollar for no more the $75.
Old 10-23-2010, 07:31 AM
i have a snap-on that still works after 20+ years, but snap-on tends to relabel tools like this that are made by others, so search around.
206 637 4071
Old 10-23-2010, 08:56 AM
Platinum Member
dad911's Avatar
They are pretty basic. 2 gauges with an orifice in between, and a regulator. Discussed here: leak down test
Mine is a MAC, and has always worked fine. Get one with 2 gauges.
Old 10-23-2010, 09:19 AM
jamesjedi's Avatar
Thanks for the help. I will look for one that is not over priced.
Old 10-23-2010, 10:45 AM
Senior Advisor
James Brown's Avatar
Check Aircraft spruce or Brown tools or ATS tools for aircraft cylinder leak down tools. Most around $100. For aircraft engines (small displacement below 375 C.I.) the orifice is .040 Not sure what Porsche requires but these should work.
08 Cayenne Turbo
Old 10-23-2010, 12:29 PM
