Replacing Alternator, a few questions.
I am in the process of replacing my alternator on my '74 and I have a two questions.
#1) What's the deal with the ground strap? I'm not sure it was installed properly, and I don't know where it it supposed to go. Does it run through the back of the air duct? It wasn't when I took it apart... ![]() #2) Is this ground strap in usable condition, or should it be replaced? ![]() Thanks! |
ground
my ground strap connects to teh back of the alternator after the deflector is installed,, your looks like it may need replaced.
1975 911S Targa Silver Anniversary Edition |
To one of these?
It's been a long time since I've taken an externally regulated 911 alternator apart, but every alternator of every year I've touched for a 911 has all the wires running through the deflector onto the back side of the alternator, including the ground.
By the way, that ground is toast. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
The ground lead is connected from the alternator to one of the engine case bolt/nut. Tne ground strap shown is toast.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
DriverX, yes to one of the studs in your last picture(right lower side).
John
997 C2S 2005 "Slate grey"(special order 1965color) 911 SC 1978 Silver/black 34.000 miles from new! 911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black |
ground on mine
My ground is on one of the deflector nuts. That is how it was when i took it apart the first time....
Where would it connect if you go through the center of the deflector?
Excellent question 47Silver!
I couldn't see where you would hook up the ground strap to the alternator, but connecting it to the deflector makes sense to me. |
it can hook to any of the studs in the back of the alternator. if you look carefully some of them are insulated from the body of the alt (dont use those). if yours was not grounded properly, i would ground it and test it before buying a new unit. it may be the only thing wrong with it.
poof! gone |
this would work fine. probably not the way the factory did it..but the alt case is grounded all the same.
poof! gone |
A more "certain" ground is as mentioned....run thru the center of the air deflector and solidly to one of the upper case-half-studs. Use a large diameter wire. IIRC, my 85 Carrera used a large, insulated style cable to an upper engine stud. Attaching it to the alternator air deflector stud may still "show" ground, but IMHO would be a more indirect method of high-current-handling-capability contact.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Where wiring is concerned...cleanliness is AHEAD of godliness.
If you are not willing to lick the end of the wire and the stud on which is about to be installed (not actually licking it) then the wire and the stud are NOT clean enough!!! If there is any resistance in the connection, there will be heating at the joint. This will throw all the controls and guages off, make lights dim, play havoc with engine control boxes, create stutters and stalls in the ignition, and anything else bad that could happen to electrical things. I cannot count the number of times I have fixed friends cars and bikes by simply cleaning and repairing the main and aux grounds on the machine. If it ain't shiny .... it ain't gonna work right.....LOL Bob
Bob Hutson |
Tru dat, I drove a '66 Beetle w/6v system every day for 3 years so I'm familiar with potential for corrosion and it's effects. I degreased the area today and I'm going to see if I can shine up that ground strap. Actually doesn't look that bad without all the grease on it....
