Keepin' it Simple...
Replacement Drop Link Bushings for Weltmeister Stage 2 Sway Bars
Hoping this will save some people a little time/frustration. My 911 project car came with 19mm Weltmeister sway bars front and back but the drop link bushings were toast at all 4 corners. Here are the part numbers:
Bushing half = P913960 (2 req'd per drop link, ~$4/ea) Metal sleeve for bolt that runns thru the bushing(s) = PZC-SB-5000J (~$5/ea) ![]() If you just need the bushings, that part number does come up on their website (you know the one). The sleeve will require talking to someone on the phone if you need those, too (like I did). It took me a number of tries to find someone willing to track down the numbers for me... As most people that use the Weltmeister bars already know, everything is SAE/inch hardware instead of metric. Nothing else that I was able to find (in terms of drop link bushings) works in these bars but the part numbers listed above. They are direct replacements. Even the PB-1013 set wasn't correct as those parts were designed for the factory non-adjustable front sway bar drop links. Hope that helps,
-Doug 1968 911R Clone; 11/07-?? (forever the project car ![]() 1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
Five times a charm? I may have that same bushing, cannot use on my 1977, PM me if you want a single spare.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Just ordered the bushings with Automotion. They have in stock. They have their own part numbers. This is for droplink bushing for rear sway bar. Give the part numbers listed above post. They are going to send 2nd day air for no charge. WOW!
Just recieved rear drop link bushings for weltmeister sway bar stage 2 from Automotion.
Automotion part #s sleeves- 229242 Rubber bushings- 229243 Hope this helps anyone looking for them. They have in stock. |
RosePasssion in france now own Weltmeister.I got rear arb bushings from them.
Thread Tools | |
Rate This Thread | |
