-   -   Cyl. temp sensor question. (http://forums.pelicanparts.com/porsche-911-technical-forum/572647-cyl-temp-sensor-question.html)
bklyn 10-30-2010 01:14 PM
Getting ready to change out the temp. sensor on my 87 Targa, I have read a few of the post and it appears straight forward. My question, is the special socket needed and if so what is the size? Can I cut one of my own using an old deep socket? Thanks LennySmileWavy
Walt Fricke 10-30-2010 03:27 PM
Don't need special socket to remove, just cut wire off. Yes, you can slot the side of a socket, same as the tool, to reinstall without damaging the wires.
I remember having the most trouble with the nice rubber wiring gasket, either getting it out or the new one back in. I wasn't able to make a neat job of it in any case. Disappointing for a guy who thinks he is handy mechanically. But no issues with the sensor function.
Walt
Flat6pac 10-30-2010 04:13 PM
Did you ohm it for the resistance? That would be your only reason for change.
Bruce
bklyn 10-30-2010 04:22 PM
Bruce, what should the resistance read, I can not find it in the Bentley only the speed sensor and o2.
Britwrench 10-30-2010 04:27 PM
Bruce
If the sensor was the older style one with only one wire terminal in the socket, that would be a reason for changing it. Before it fails.
bklyn 10-30-2010 04:29 PM
Yes, it still does have only a one wire set up that was my oring. reason for ordering a new one.
rvctyjim 11-01-2010 10:29 AM
Yes...
14mm deep-well socket,3/8 drive,6 point.
You will have to grind one side down to the base of the socket...Works great!
http://forums.pelicanparts.com/uploa...1288632392.jpg
http://forums.pelicanparts.com/uploa...1288632412.jpg
