Senior Member
Leland Pate's Avatar
Question Motorcycle jack to remove engine?
Update?
I remember a gent saying he had bought one of these and was going to try to see how well it worked on a 911 engine.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=41644
Update????
I'm NOT going to use a tranny jack again!
Chief Architect and Mastermind,
SCWDP
Old 01-19-2002, 04:32 AM
Senior Member
Doug Zielke's Avatar
Lee, I have one and almost brought it to Supermans engine drop. (I say almost, as I thought better of the idea in regards to crossing the border with it...too many questions from the Customs.)
I've placed it underneath the car for a look and it seems ideal for the job. Works very well on my motorbikes, too.
BTW...send me a PM and tell me how many decals you need over there. They're going like hotcakes!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-19-2002, 06:36 AM
Have you guys seen/ tried the engine cradle/ jack adapter the guy on ebay sells (he manufactures them). Its made to hold an engine and transmission as a single unit . It looks pretty effective.
Old 01-19-2002, 11:40 AM
Regardless of what kind of cradle one has, it comes down to the stability of the jack you are using. The POS that I use will never see another engine drop (literally...BTDT). The disc rocks in it's bore and the wheels aren't far enough apart......your basic $90
Sears thingy. I even welded a 10 X 8 plate to the disc.....helped not at all.
The land battleship that J. Walker posted a pic of is what I really need, but can't justify the expense.
Gonna take a real hard look at the HF motorcycle widget.
JPIII
Early Boxster
Old 01-19-2002, 04:07 PM
Platinum Member
dad911's Avatar
I've used a 'motorcycle' jack to remove/replace '84 drivetrain twice. (Rear seal leaked first time, had to do it again) Much easier than a regular jack alone.
Bought it at Costco around $100. My only complaint is that it has a 'lever' to release pressure and it drops too fast. Try to find one with a 'screw' like a standard bottle jack.
Old 01-19-2002, 05:32 PM
marcesq's Avatar
Jay:
I have purchased several tools from Paul Wilding. All products have been super high quality and Paul is a pleasure to deal with.
I spoke to Paul about the engine drop unit because I thought my 2.7 was heading for the floor this winter. Turns out that studs were all in place and the noise was a valve tapping.
If you have any questions Paul's e-mail is PAUL_WILDING@email.msn.com.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 01-19-2002, 05:35 PM
Thanks for the input. I'm glad to hear his stuff is as good as it looks. He seems like a pretty nice guy too.
Old 01-19-2002, 06:34 PM
I was looking at the same thing after receiving my Harbor Freight catelog. Looks like it might work well.
Old 01-19-2002, 07:14 PM
Speaking of harbor freight, try their long frame standard jack. It looks huge, but its really a standard jack (which means the jack pad isn't any taller) with a longer arm. It really gets the car up a LOT higher. Cost is 150, but they have them on sale sometimes for 100. Much nicer work enviorment.
Old 01-19-2002, 07:56 PM
cary's Avatar
Lee, went and looked at a motorcycle jack this afternoon in Missoula. Interesting. $99. 1500 lb.
Basically a bottle jack with a scissor lift. Needs about 15 inches of clearance. No problem, with the car on jacks.
Nice wide platform. About twice as wide as my floor jack. Front wheels straight. Back wheels swivel.
My only concern, is that the scissor lift collapses toward the shift coupler. With much more forward travel than the floor jack. Because of the scissors. So you have to pull back as you lower the shift rod out of the tunnel.
You'd want to put an 800 weight on it and see how much control you have with the valve on the bottle jack. Too fast and it would be worthless.
My 02c.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 01-20-2002, 06:13 PM
rob911's Avatar
UK tool source
Similar (very) item available in UK.
http://www.machinemart.co.uk/product.asp?p=020110392&r=2051&g=107
Wonder if I can hire one?
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 01-22-2002, 10:23 AM
jtf914's Avatar
For those who prefer not to use eBay, Pelican now sells Paul's adapter tool. Here is the link:
http://www.pelicanparts.com/Porsche/catalog/tools/jacks.htm
Justin
My Dyno run:
http://www.youtube.com/watch?v=9i8E51PmUgw&sns=em
Old 01-22-2002, 11:12 AM
83930's Avatar
Send a message via ICQ to 83930
I've used my motorcycle jack to take my turbo and transmission out. Works well. Jack I have lifts to 24 inches is good for 1000 lbs. and has a 5 ft. t-handle bar for guiding the jack around. The handle is removeable and I did have to put a two-by-four under the bell housing to get the weight off the shift rod in the tranny,but it went in and out in 45 minutes.
Neil
83 930 3.3
Old 01-22-2002, 05:06 PM
