Halm's Avatar
Pulls right Under Braking
Last Sunday, a buddy helped me install new rotors and pads on my 1980 SC. Everything went as expected. New ATE rotors and Mintex Redbox pads. After the install, we bled both wheels and the brake pedal has never felt better. The hard lines look fine and the ss braided flex lines are less than a year and look good too.
However taking it out for a relatively short test drive, it pulls slightly to the right under moderate - hard braking.
I am out of town and thinking about what might be going on here and making a check list for the weekend. The new setup doesn't have 20 stops yet and my hope is that this is just a break-in / bedding issue.
So the question is what else should I look at and/or double check? How would one "exercise" the calipers to make sure they are functioning correctly? Any and all thoughts are welcome.
'17 Cayenne
Old 11-02-2010, 06:52 AM
Fleabit peanut monkey
Bob Kontak's Avatar
You need to get those bad boys stinkin' real bad before you can say they are broken in. Given the number of posts you have, I suspect this is old news.
Old 11-02-2010, 06:59 AM
na2ub's Avatar
Break in the new pads / rotors more, and re-bleed the whole system. Last time I ended up bleeding the front brakes 2 or 3 times before I could get both wheels to lock up at the approximate same time, although that is influenced by corner weights, too. I would re-bleed the fronts, at a minimum. If it is only a slight pull, I would not suspect that your calipers are misbehaving. Much more likely a bedding / bleeding issue.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-02-2010, 07:48 AM
Make Bruins Great Again
Por_sha911's Avatar
You probably spread one caliper out farther than the other side and there is not enough pressure in the system to make it lock. See if one side spins freely and the other has the normal drag.
Joe
Old 11-02-2010, 12:11 PM
Max Sluiter
Flieger's Avatar
If you can't smell them, go faster and stop harder.
New Pad Bedding/Break-In
Old 11-02-2010, 12:12 PM
Halm's Avatar
Thanks everyone. I appreciate the help.
'17 Cayenne
Old 11-02-2010, 05:50 PM
RETIRED
Joe Bob's Avatar
Probably a Republican set of pads...
Old 11-02-2010, 06:09 PM
