Need help with msd install
Installing an msd-6btm, i have everything figured out except the wires to the distributor, msd tech says my single wire to the distributor is actually 2 wires, one is spiral wrapped around the main wire. Before i cut it i would like to here from someone here who has installed msd in their car. What did you do here?
Any help? |
The plug to the original CD has the green wire split to two pins. Rather than cut mine I just connected the MSD to the original plug with spades.
| All times are GMT -8. The time now is 04:37 AM. |
