Piston rings close to design life span or not
Hello folks, I continue to assess a top end rebuild/fix on a 1986 911 Targa. An unscheduled rebuild due to broken head bolts found during a valve adjustment.
Currently assessing the piston rings for keep or replace. The gap for the compression rings (top two) shows 0.50MM/.020" the wear limit suggests 0.80mm. Question: Would you keep or replace with new. Can I realistically expect to get new installs with a 0.2mm gap. With 0.3mm remaining to wear limit, would you leave them in.. (MAHLE Pistons).. Thanks for any help.. I believe I dropped this in the technical forum in error, I wonder if a moderator can flip it over to the rebuilding forum for me.. Last edited by aquazulu2; 04-09-2014 at 10:33 AM.. Reason: add 0. |
Replace them for sure, they get brittle.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
I would have to agree, replace them.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I don't know how or why head bolt failure led to this question but once the piston rings are outside the cylinder jug I would NOT attempt to re-use, compress and re-insert.
Sorry for the dump, New piston rings in the basket.. |
