I'm a loser, baby.
Leaky windshield question.
Mine leaks at the lower corners like a lot of others have mentioned.
Question is, is the leak typically between the windshield and seal or the body and seal? I assume the body and seal? |
Most likely between the body and seal. I can only tell you, you should get on it ASAP to remove the windshield, find out the damage, and fix it. I had a '72 that leaked on the driver side when it rained. When I took out the windshield, I found the metal forming the windshield frame in that corner and the metal under the dash pad badly rusted out. It most likely started long before I bought it, and the PO(s) didn't do anything about it. Of course I didn't find out until I drove it in the rain - one of the few times I did.
Marv Evans '69 911E |
I'm a loser, baby.
Thanks for your reply.
I just did a new seal in my '86 Carrera, no more leaks. I did use a little bit of plumber's putty in one of the upper corners to keep the seal lip from collapsing into the frame. It is a soft putty that never hardens. It is the cheap version of the stuff Porsche used on OEM installs. This is a relatively easy project, biggest issue is always cleaning out the crud that is in the frame, and any sealant that the last moron used.
09 Cayenne GTS: GTS red, race car tow vehicle 86 Porsche Carrera, GP White- E Class PCA Club Race Car 71 Porsche 911T Targa, Silver, Sport seats, 2.7RS spec motor. 90 Porsche 928 S4 w/ 37K miles Grand Prix White/ Cashmere 73 Karmann Ghia Cabriolet, Black, 1776 Turbo, 250hp |
