Big Red Brake Up Grade
I am upgrading my1980SC brakes to 993TT Front Calipers and I think the Rear are
GT3 (can't tell as no markings) .I bought them off a Doc who said they were both 993TT but don't think they are . Anyway I have to adapt the rear arm to fit rear caliers . Can anyone tell what Master cylinder I will need or will I need to fit a pedal box ,or can you recommend options .cheers Dave |
Senior Advisor
I think the stock sc mc will work. If not, go with the turbo one.
08 Cayenne Turbo |
You will need a 23mm MC for those calipers.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Grand Am/IMSA Data Guy
I have a similar set up on my 84. Installed the turbo MC and has worked well for many track events. Great set-up. Never have a soft pedal at the track. Just make sure you get them on the correct side of the car. The calipers have a small piston and a larger piston. the small one needs to be the first one the rotor passes. If your's are not that way, flip the bleeders and the bridge.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
I use a 23mm and works good. Jeff
993 Twin Turbo Brakes and kit for 911SC
thanks guys for your help cheers Dave
