sporto to manual conversion
I want to convert from sporto to manual. I was thinking, can you just remove the vacuum operated solenoid that engages and disengages the clutch. Then just install a manual clutch cable. What do you all think.
Old 11-12-2010, 08:16 AM
Peter Zimmermann's Avatar
To convert a Sporto to a manual trans, you will need;
1x transmission with throw out bearing release fork/parts
1x flywheel
1x clutch (disc, cover & TOB)
1x shift tower
1x pedal assembly
1x clutch cable
Miscx speedo-related items
1x front trans mount
Miscx hardware, oil lines, CV joint components, etc.
...and a lot of time! BTW, many of the above parts will be different depending on which trans you use (901, 911, 915, etc.).
Keep the Shiny Side UP!
Pete Z.
Old 11-12-2010, 08:40 AM
Zeke's Avatar
I can understand wanting to convert as I have ridden in one frequently. No soul. But, they are cool in a way and I understand Porsche raced the Sportomatic in rallies.
Is it dead, or are you just wanting a 5-speed?
Old 11-12-2010, 08:56 AM
I just want a manual. I already have the tranny, But i started thinking that it must all be the same except the clutch engage and release. I am going to keep all the parts just because they are so rare. I thought that the sporto tranny has a standard clutch and FW.
Old 11-12-2010, 09:18 AM
It also has a torque converter...
Used to drive one occasionally, if you shift 'smartly' through all 4 gears, it was moderately peppy as I recall.
A slug if you start in 2nd then shift to 4th.
Didn't they run a couple Sportos in the early 70's, won class at LeMans and were 5th or 6th overall?
(Hmmm, am I recalling correctly that these were 914-6's with Sportos?)
Old 11-12-2010, 09:59 AM
layzee's Avatar
This is a much more involved job than you suggest. I'd also urge you not to do it, but its your car.
The conclusive list is on this thread: DDK - Die Deutschen Klassiker :: View topic - cost of converting a sporto
Phil Garner
'72 911E Sporto
Sportomatic.org
Old 11-12-2010, 01:43 PM
