sporto to manual conversion
I want to convert from sporto to manual. I was thinking, can you just remove the vacuum operated solenoid that engages and disengages the clutch. Then just install a manual clutch cable. What do you all think.
To convert a Sporto to a manual trans, you will need;
1x transmission with throw out bearing release fork/parts 1x flywheel 1x clutch (disc, cover & TOB) 1x shift tower 1x pedal assembly 1x clutch cable Miscx speedo-related items 1x front trans mount Miscx hardware, oil lines, CV joint components, etc. ...and a lot of time! BTW, many of the above parts will be different depending on which trans you use (901, 911, 915, etc.).
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 11-12-2010 at 10:47 AM.. |
I can understand wanting to convert as I have ridden in one frequently. No soul. But, they are cool in a way and I understand Porsche raced the Sportomatic in rallies.
Is it dead, or are you just wanting a 5-speed? |
I just want a manual. I already have the tranny, But i started thinking that it must all be the same except the clutch engage and release. I am going to keep all the parts just because they are so rare. I thought that the sporto tranny has a standard clutch and FW.
Used to drive one occasionally, if you shift 'smartly' through all 4 gears, it was moderately peppy as I recall. A slug if you start in 2nd then shift to 4th. Didn't they run a couple Sportos in the early 70's, won class at LeMans and were 5th or 6th overall? (Hmmm, am I recalling correctly that these were 914-6's with Sportos?) Last edited by tcar; 11-12-2010 at 10:21 AM.. |
The conclusive list is on this thread: DDK - Die Deutschen Klassiker :: View topic - cost of converting a sporto |
