-   -   Help! Engine lid does not open!! (http://forums.pelicanparts.com/porsche-911-technical-forum/574870-help-engine-lid-does-not-open.html)
83_Silberpfeil 11-12-2010 08:39 AM
My engine lid won't open!!!!
I pull the engine lid latch handle and do feel very solid tension. However, the lid will not pop open.
Are there any 'emergency' manual way to open --- a la manually cranking the sunroof to open/close?
Much thanks in advance!!!!
kodioneill 11-12-2010 08:42 AM
Have some one pull up on it while you pull the cable. If the cable is broken the lid should pop up.
Zeke 11-12-2010 08:59 AM
As is usually posted, drive on an unlevel surface flexing the car while pulling the cable. One wheel up a curb or something like that. Go both ways.
Then take time to find out how to adjust the plunger.
83_Silberpfeil 11-12-2010 08:59 AM
Thanks for quick reply!!! I will try that tonight.
If cable is broken, I suspect PP will carry that part --- what's involved to replace it??? Massive removal of interior trim?
kodioneill 11-12-2010 09:06 AM
I think you slide it through a metal tube that is welded in place that terminates at the latch.
D911SC 11-12-2010 09:10 AM
Tube runs through LH rear wheel well - along the top but on the inside of fender. You can see it come out of the back of the door post panel.
83_Silberpfeil 11-12-2010 09:51 AM
Yes --- where the latch handle is located.
Any idea if new cable s/b 'threaded' starting from the latcg handle, or from the engine cimpartment side?
Thanks to all for your knowledge!
kodioneill 11-12-2010 10:09 AM
Plastic "T" handle fixed to a wire that is connected by a set screw to a barrel at the latch.
HawgRyder 11-12-2010 11:27 AM
If you change the cable...remember to grease the heck out of it as you push it into the tube.
Bob
